87 Camaro wont start
Old Sep 17, 2012 | 07:30 AM
1st thirdgen's Avatar
Driving car to work at 4am, driving about 50 mph car would not accelerate any faster. let off the gas pedal and the check engine light came on then stalled. would not restart not enough juice in battery. after work replaced battery and still no start saw lots of fuel leaking by the IAC valve. after inspecting, gas was shooting out of vacuum line for the Fuel Pressure Regulator. Replaced Regulator. now no leak but car still will not start. Brand new battery but seems there is not enough power to start. Car cranks but not enough to start. Seems like it is very sluggish. Cranks strong then stops cranking turn off key and try again same thing happens strong then bog. At a loss. please help. any suggestions?
Old Sep 17, 2012 | 05:53 PM
fasteddi's Avatar
Car: 1991 Camaro RS
Engine: Lq4 6.0 SBE s485 turbo E85
Transmission: Fsi th400 stage 4. TSI 5500 st
Axle/Gears: Strange S60 4:10s
Re: 87 Camaro wont start
You were driving to work with the lights on right??? Were the lights dimming as the car started to die? Just sounds like that car dieing initally was dues to a charging issue as the battery even a brand new one will only work for just a bit before it needs the alternator to do the work and keep the ac/dc charging and rectification going.
Im thinging that your alternator may be bad. You could remove it and take it to autozone or a place like that, they will check it to see if its bad for free. If its not, well then you know its good. If its bad, a new one cost about 70 bucks at autozone for a new one and your good to go.
Old Sep 17, 2012 | 07:41 PM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
I would get the alternator check.
Old Sep 17, 2012 | 08:01 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Take the plugs out and crank the engine (with the ignition coil disconnected from the wiring harness at the GRAY connector). If fuel was shooting into the plenum like you described, you may have hydrolocked a couple cylinders...
Of course, make sure the battery is charged and get the alternator tested first...
:edit: And then change the oil...
Frozer!!!
Jan 19, 2024 04:55 PM
92camaroJoe
Jul 29, 2023 07:57 PM
Caspar
Jun 19, 2016 11:19 PM
92camaroJoe
Aug 13, 2015 06:07 AM
