boging at lower speeds.
Old Jan 24, 2013 | 03:12 PM
thatoneguy5x's Avatar
Car: camaro
Engine: 3.1
Transmission: auto
like the title says my car is boging when im slowing down or coming to a stop usually noticeable at about 0-15 MPH but above that drives fine, when im sitting in stop and go traffic i always have to ride in the right lane so if my car dies i can pull over on the shoulder.
when it bogs my volt meter dips down to about 7 or lower and keeps kicking back up and down, all my lights dim up and down like its about to die, its only died on me once lukily i was pulling into a parking lot at the time. it usually does this when the car is warmed up.
its a 92 3.1 camaro with new plugs, wires, rotor, dist cap, battery, fuel filter, oil change, pcv valve, and a a couple other things here and there. sugestions welcome, thank you in advance
Old Jan 24, 2013 | 03:25 PM
W.E.G.'s Avatar
Car: 88 Sport Coupe Camaro
Engine: V6 2.8
Transmission: Borg-Warner T-5
Axle/Gears: RPO/GU6: 3.42
Re: boging at lower speeds.
checked for vacuum leaks?
Old Jan 25, 2013 | 01:34 AM
Car: camaro
Engine: 3.1
Transmission: auto
visually checked but not with any type of smoke machine or spray ive changed a couple hoses it does make sense tho
Old Jan 25, 2013 | 05:07 AM
fasteddi's Avatar
Car: 1991 Camaro RS
Engine: Lq4 6.0 SBE s485 turbo E85
Transmission: Fsi th400 stage 4. TSI 5500 st
Axle/Gears: Strange S60 4:10s
best way to check is to toss a vac guage on it at hot idle and see where its at in inches of hg. Then you can also start to spray some carb cleaner arround all gaskets on this intake and vac lines.
Old Jan 25, 2013 | 05:17 AM
Car: camaro
Engine: 3.1
Transmission: auto
does autozone rent these out???
Old Jan 25, 2013 | 02:43 PM
fasteddi's Avatar
Car: 1991 Camaro RS
yes they usually do rent them out.
Old Jan 25, 2013 | 03:28 PM
Car: camaro
Engine: 3.1
Transmission: auto
awesome do i connect it to like the brake booster hose or just any vaccum hose or is there a special port for it
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
loud91rs
Oct 5, 2015 10:05 PM
1HotZ28&SS
Sep 28, 2015 08:58 PM
