Is there one v6 That runs great on here?
Old Mar 10, 2013 | 10:54 PM
  #51
kmcn47's Avatar
Car: 84 Trans Am, 84 Fiero, 86 944
Engine: 5.0, 2.5, 2.5
Transmission: 5spd
Re: Is there one v6 That runs great on here?
Originally Posted by XxXChrisGXxX
poorly designed gaskets and engine.
probably why everyone else's leaks so badly all the time too
Old Mar 11, 2013 | 05:00 AM
  #52
fasteddi's Avatar
Car: 1991 Camaro RS
Engine: Lq4 6.0 SBE s485 turbo E85
Transmission: Fsi th400 stage 4. TSI 5500 st
Axle/Gears: Strange S60 4:10s
It is only placed on the china wall...and corners...it is black RTV...and it was torqued to specs and super clean.
The timing cover was also super clean, and I put a thin coating of blue RTV on both sides of the gasket as well as a good bead on the oil pan gasket where they meet.
Everything was done properly...it just decided to leak...why who knows...poorly designed gaskets and engine.
Ive never had a issue with the china wall leaking. Torn mine down at least 3-4 time now. Black RTV and the Copper orange stuff is all I keep in my garage. The key is snugging that lower intake down right, but first putting on your rtv and letting it sit for a little bit. Just enought to make it tacky. I always let my rtv sit a bit on the gaskets and metal plains for a while(20 min or so) just so that its tacky.
There are some issue areas on our V6's but the motor itself is a solid one I believe. I never had a major problem else then leaky freeze plugs, leaky o ring on the dizz,y and sensors which are going to go bad eventually on a 20 year old motor.
Old Mar 11, 2013 | 08:04 AM
  #53
XxXChrisGXxX's Avatar
Car: 1987 Chevrolet Camaro
Engine: 2.8L V6 MPFI
Axle/Gears: 10 Bolt
I did everything I could. I took my sweet time cleaning it, adding a good amount of black RTV in a steady bead. It just decided to leak alittle bit of oil at a time.
I am redoing it come spring break -- for me. Hopefully, this time everything will go smooth.
So let it sit for 20minutes or so then install?
Old Mar 11, 2013 | 08:29 AM
  #54
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
100% clear silicone in a caulk tube from walmart $2, cheaper, as good as the rest, doesn't stand out like a sore thumb, easier to apply a bead with a caulk gun.
even works on exhaust connections... no donuts leaks on the Buick, good slather on install, never leak. [wish there was room enough to re-do the 2.8 ones, leaks like a sive on right]
Old Mar 11, 2013 | 10:08 AM
  #55
Axle/Gears: 10 Bolt
Really? Clear silicone? Hmm, it can handle the temperature and such?
Old Mar 11, 2013 | 10:20 AM
  #56
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Yea, "100%" clear silicone
Old Mar 11, 2013 | 10:28 AM
  #57
project89's Avatar
General-purpose, clear RTV indoor/ outdoor sealant. Seals, bonds, repairs, mends and secures glass, metal, plastics, fabric, vinyl, weather stripping and vinyl tops. Protects and repairs electrical wiring. May be applied to horizontal or vertical surfaces.Waterproof and flexible. Temperature range -75°F to 400°F (-59°C to 204°C); resists water, weather, and vibration.
it is not oil/grease chemical proof
Old Mar 11, 2013 | 10:31 AM
  #58
project89's Avatar
this is ultra black
OEM specified. For dealership warranty requirements, Ultra Black® ensures extended drivetrain warranty compliance. Fast-curing formula. Sensor-safe, low odor, noncorrosive. Meets performance specs of OE silicone gaskets. Retains high flexibility, oil resistant properties through use of a patented adhesion system. Temperature range -65°F to 500°F (-54°C to 260°C) intermittent; resists auto and shop fluids and vibration.
here is ultra grey
OEM specified. Permatex® Ultra silicones were developed to meet today’s technology changes. Sensor-safe, low odor, noncorrosive. Outstanding oil resistance and joint movement tolerance. Eight times more flexible than cork/composite gaskets; three times more oil resistant than conventional silicones. Temperature range -65?F to 500?F (-54°C to 260°C) intermittent; resists auto and shop fluids and vibration.
use one or the other
Old Mar 11, 2013 | 10:43 AM
  #59
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
dunno where you got that but yes it is, anyone with a dirt bike knows first hand, headers are only held on with springs for wrecks, one good jar and it can open up and suck air, bye bye piston, silicone directly on the header doesn't even flinch.
if the hot oily exhaust from a 2stroke can't harm it......... 2+2= get a new source for info.
Did the same thing on my 9sec drag bike, kaw 750 triple 2 stroke with dirt bike expansion pipes.
Old Mar 11, 2013 | 10:50 AM
  #60
project89's Avatar
thats straight from permatex if they say it isnt oil/chemical resistant i believe it.
maybe other brands are resitant to it but they say theres isnt
Old Mar 11, 2013 | 08:46 PM
  #61
HiPerf_Chevyman's Avatar
Car: 1991 Camaro RS
Engine: The Wicked six'ah
Axle/Gears: stock 3.08's
Wow dont even get me started on the past few posts about Clear sealant. Ive been at this for a few days. and I'll tell you right now. Anaerobic gasket maker is the stuff to use. I"ve spent a few days working on Volvo's, Saabs, VW's. and always use this stuff. and ive never had a customer come back with something Still leaking. Between this and "Right stuff" for Parts store Gasket maker your in the right direction. Dont Use window Sealer from walmart for christ sakes people.
Old Mar 11, 2013 | 11:05 PM
  #62
kmcn47's Avatar
Transmission: 5spd
yeah, not to step on toes or anything but looking at what I've seen of Dave i believe him more when it comes to a v6 thirdgen, dave? is there anything concerning v6 thirdgens you're not good at?
eightsixseven
Dec 16, 2024 01:50 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
Fast355
Dec 2, 2016 06:33 PM
justin57
Aug 20, 2015 07:05 PM
