V belt replacement help please!
Old Apr 20, 2013 | 10:24 PM
Jdvorsky's Avatar
I'm trying to replace the v belt on my 1986 2.8l Firebird and I dont know what to loosen to get the new belt on.
The V belt is on the crank pulley, water pump and power steering. I can't figure out what loosens/swivles to get the new belt on. the old belt just came off because it was so stretched.
thanks in advance for the help
Old Apr 21, 2013 | 12:19 AM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
Re: V belt replacement help please!
The adjustment is on the power steering pump. The water pump and crank are bolted solidly to the block, you're not gonna move them. IIRC, the adjustment is on the back of the steering pump. If you look on the back of it, you should see a bolt that goes through a slot in the backer holding it to the block. You'll have to loosen the bolt(s) on the front of the pump a bit to make it easier to move.
1992 Trans Am
May 10, 2023 07:19 PM
Navy8125
Aug 22, 2015 07:13 PM
mustangdmurder
Aug 21, 2015 07:17 PM
TRANSAM82-92
Interior Parts Wanted
Aug 15, 2015 01:26 PM
scottmoyer
Aug 9, 2015 10:18 PM
