Possible ECM problem
Old Jun 26, 2013 | 06:31 PM
hokiefanatic93's Avatar
Car: 1987 Camaro
Engine: V6
I bought a 1990 camaro so i can resell it since it was so cheap. in my effort to get it running for some extra cash i plugged the ecm of my 1987 camaro into the 1990 camaro thinking it would bypass the 1990+ camaro security system. it did not work. so today i put a new starter in my car and put the ECM back in and now my car runs like total crap. it stutters and backfires when i give it gas now and when i try doing the code test the cars check engine light no longer flashes or even turns on for that matter. Is it possible that by putting the 87 ECM into the 90 camaro i screwed the computer up?
Old Jun 26, 2013 | 07:40 PM
mcrandrz's Avatar
Car: 1991 camaro rs
Engine: 3.1 - looking to upgrade to 3400 hy
Axle/Gears: Stock? Lol
It shouldn't. If I were to guess you had a fuel or vats issue and swapping the ecu's was irreverent.
Posted from Thirdgen.org App for Android
Old Jun 26, 2013 | 07:41 PM
mcrandrz's Avatar
Car: 1991 camaro rs
Or a clogged cat.
Old Jun 26, 2013 | 08:08 PM
fasteddi's Avatar
Car: 1991 Camaro RS
Engine: Lq4 6.0 SBE s485 turbo E85
Transmission: Fsi th400 stage 4. TSI 5500 st
Axle/Gears: Strange S60 4:10s
Re: Possible ECM problem
Are you saying that you took the ecm out of a pre 1990 v6 car and put it into a 1990 V6? Swaping out computers isn't that easy exspecially when your talking a Mass Air Flow car (1987) to a Speed density car(90-92)
I cant say for certain that your messed anything up but for future reference do some research before swaping ecms. Because MAF and speed density are so much different let alone the 7730 ecm in the 1990-92 thirdgens is a whole different one then they 302 one you had in the 1987.
Old Jun 28, 2013 | 08:10 AM
armos's Avatar
It's possible. The pinouts are probably very different, so you could have shorted something in the ECM when you plugged it into the 1990 harness.
Does the CE light not even come on when you first turn on the car? If not, then that does imply the ECM might be dead.
Old Jun 28, 2013 | 02:04 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
first easy thing, open the ECM and look for burnt sectino of the board. That can help clue in to what popped.
Old Jun 28, 2013 | 02:58 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Yes, your '87 ECM is toast. Didn't the fact that the '90 ECM has three connectors and the '87 ECM only has two provide a hint? The connector pin-outs between the two of them are completely different.
You need a new ECM for your '87. And hopefully none of the sensor or actuators in the '90 car is toast...
RBob.
Eric2ndGen
Nov 5, 2015 01:51 PM
mddaniel
Sep 8, 2015 05:16 PM
inferno15
Aug 29, 2015 01:48 AM
355tpipickup
Aug 19, 2015 10:02 PM
djmarch
Aug 10, 2015 08:42 AM
