little help for a question
Old Sep 4, 2013 | 11:01 AM
JC1992rsconvert's Avatar
Car: 1992 camaro rs convertible
Engine: 3.1 liter v6
Transmission: automatic
Axle/Gears: 3.23 posi trac
ok so back in april my car started to act up. took it to my machanic and over the phone he told me it needed a new oil pump, no problem or so i thought. went up there to talk to him about it and and he then proceeded to tell me that my engines bearings are shot and honestly i believe him because at idle the cars fine for about 3 minutes then after that the rpms will go down then when you start down the highway it will bog itself down. Now since the stories done heres my question, my mom has a 1995 camaro coupe that she wrecked and it has a brand new transmission in it hooked up to a 3.4. i plan on putting her engine block into my car but can i put her entire engine in including the transmission. ive read the articles about how to do the swap for a 3.4 and i was just wondering what all i would have to change. i know the simple things like the ecm and harness but what else would go with it. thanks for the help guys
Old Sep 5, 2013 | 05:07 PM
UK Speedbird's Avatar
Car: 91 Firebird
Engine: 3.1L 191ci
Re: little help for a question
Hi JC,
There ''was'' a thread here somewhere about the 3.1 to 3.4 swap that I did read a while back but I can't find it now. Thought I'd reply as no one else has, so I might not be much help. First of all don't condemn your old engine, are you sure your bearings are shot? Does it make alot of noise from the bottom end? The symptoms you describe could be something more simple and a lot less ££££ than you think. I'd get a second opinion before ditching it.
As far as I'm aware the 3.4 and 3.1 are exactly the same engine basically, and from what I can remember you can bolt it straight up to a TH700 autobox. You'd have to swap over the plenum's as they are the one thing that's totally different. You'll just have to see how you go with other peripherals as to see what needs changing, as I've found there are even slight differences between the 2.8 and the 3.1! My friend had a a 87-88 (i think) 2.8 and that had a MAF sensor on it where mine has just a MAP sensor.
That kind of thing would then dictate which ECM you'd have to use.
Have a look round for that thread, or ask on one of the engine tech boards I'm sure someone will be able to give you the proper low down.
Good luck,
Speed.
Old Sep 5, 2013 | 07:54 PM
thanks speed,
as for my engine it does make some noise coming from the bottom end and in all truth here ive been wanting to do an engine swap with this engine anyways because when i drove it i loved the little more power i got out of it. I dont want to trash my old engine but since i have another 3.1 laying around im going to use both of them to create another engine just incase, and i will check the other boards thanks.
Old Sep 7, 2013 | 09:17 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Everything from the 3.4 that is below the intake manifold stays. Except the oil pan. The distributor (remove the oil pump drive from the rear of the block), intake plenums and the fuel rail get swapped from the 3.1.
You cannot use the transmission from the 4th gen without some major rewiring.
Leave your engine control system as it is. It's a direct plug in when you swap over the intake parts. The only parts you will NOT use on the 3.4 are the crank and cam position sensors.
Old Sep 11, 2013 | 04:48 PM
that just helped out alot thanks maverick. ive decided im just going to repair my 3.1 for right now because i cant get my other engine out at the moment and i have to get back behind the motor anyways to get to the wiring for my speedometer because they dont work. anyways now im just gonna have fun redoing gaskets XD, on a side note does anyone know where to get motor mounts.
Old Sep 11, 2013 | 09:27 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
I was able to use the 3.4 oil pan on my swap, just had to switch the oil filter adapter to the 2.8.
edit: motor mounts from AZ, Advance, CSK, blah blah blah. You will not use the 3.4 frame brackets, they weird, reuse the 3.1's
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
