Vacuum hose??
Old Oct 21, 2013 | 12:44 PM
Domsfirebird's Avatar
Car: 1986 Pontiac Firebird
Engine: 2.8L V6 MFI
Vacuum hose??
So I got this hose here that was like this when I bought the car a few years ago with a screw in it. I kinda let it go since it didn't seem to affect the car. I'm just curious where it goes? I looked at a schematic of the emission hoses and it looked like it went to a part called vac. sw. but not sure. If you look at the picture and you know please let me know!
Attached Thumbnails Vacuum hose??-2013-10-21_13-14
Old Oct 21, 2013 | 01:49 PM
OrangeBird's Avatar
Car: 1989 Firebird
Re: Vacuum hose??
The EGR valve solenoid is the name of the part that the hose is connected to , and the end with the screw in it is supposed to be connected to the device right next to the solenoid that is mounted to the same bracket with it . Looking from the front of the engine , first is the EGR valve itself , behind it is the EGR solenoid , and behind THAT is the device I refer to . I know at a first glance the unit behind the solenoid looks like just some kind of wiring terminal , but it's actually a vacuum switch to tell the computer that the solenoid has commanded the EGR valve open . It's highly likely that the little plastic tit has broken off of the switch , and that's why the hose is capped off with the screw .
Tell me , do you get any check engine light while it's running ?
Old Oct 21, 2013 | 02:14 PM
Engine: 2.8L V6 MFI
Re: Vacuum hose??
Actually sometimes my check engine does come on and I checked it and its a code 32.
Old Oct 21, 2013 | 02:27 PM
Engine: 2.8L V6 MFI
Re: Vacuum hose??
Thanks for the help! I found where it went behind the solenoid! It had a old tiny piece of hose on it so I couldn't see it but when I pulled off the ripped piece there was the little plastic tip to put the hose back on! Thanks again!
Old Oct 21, 2013 | 03:22 PM
OrangeBird's Avatar
Car: 1989 Firebird
Re: Vacuum hose??
Great ! Now , hopefully that code 32 will stay away . Code 32 is EGR failure , and with that switch now reporting the proper EGR action to the computer , all should be well . The computer commands the EGR solenoid to open the EGR valve . The switch senses this application of vacuum to the EGR valve and reports to the computer that yes , in fact the vac signal is being sent from the EGR solenoid to the EGR valve . The computer then looks for the corresponding change in signal from the 02 sensor , proving with certainty that the EGR valve did , in fact , open .
Old Oct 21, 2013 | 03:44 PM
Engine: 2.8L V6 MFI
Re: Vacuum hose??
Ok great! I cleared the code so hopefully does not come back! It usually came on when I hit the highway so we shall see.
Pac J
May 17, 2020 10:44 AM
sheachopper
Jul 31, 2019 11:27 AM
FormulasOnly
Jul 23, 2018 08:47 AM
HoosierinWA
Oct 7, 2015 10:15 AM
dusterbd
Sep 29, 2015 08:40 AM
