fuel pressure test
Old Feb 1, 2014 | 07:28 PM
thatoneguy5x's Avatar
Car: camaro
Engine: 3.1
Transmission: auto
fuel pressure test
so I hooked the test gauge up and ran the car for about 2 minutes pressure was a constant 38-39psi (manual says should be between 34-47) so I went to shut the car off and when I returned to the gauge it was at around 40-41 psi is this normal?? it held at that for right around 30 minutes then it started slowly creeping down. 45 minutes later its at 38-39 psi is this right. should I be worried about leaks or did my car pass the leak test? thanks in advance
Old Feb 1, 2014 | 08:03 PM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
Re: fuel pressure test
That's better than most cars.
Old Feb 1, 2014 | 11:55 PM
Car: camaro
Engine: 3.1
Transmission: auto
well that's reassuring. im gonna try again see if I get the same results never hurts to check again.
Old Feb 5, 2014 | 07:06 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
The most likely reason that the pressure went back up is due to the fact that the engine oil pressure takes a couple of seconds to taper off after shutdown. The backup oil pressure fuel pump switch is designed to be closed above 15 PSI oil pressure.
The fuel pressure is well within GM spec, which is 20 minutes of holding pressure.
92camaroJoe
Jul 29, 2023 07:57 PM
R3500
Aug 17, 2015 12:16 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
