turns over but won't start
Old Nov 4, 2015 | 07:18 PM
cowboysfan20's Avatar
I have an 89 camaro rs 2.8. Car started and when i went to turn my headlights on it died. Itdid that twice and now i have no lights anywhere and motor justs turns over but will not fire. Any help would be appreciated as it is my only means of transportation. Thanks in advance
Old Nov 4, 2015 | 11:40 PM
antares57's Avatar
Car: 91 Firebird/88 Firebird/91 Formula
Engine: V6 3.1/V8 5.0/V8 5.0
Transmission: 4L60/700R4/4L60
Axle/Gears: 3.23/2.73/2.73
Re: turns over but won't start
Done any work to the car recently? Sounds like you have a marginally charged or bad battery. If the battery is good then your alternator may not be charging the battery and may be marginal or bad. Check them with a voltmeter or have them checked by an auto parts store. Good luck.
Old Nov 5, 2015 | 12:46 AM
[QUOTE=antares57;5977184]Done any work to the car recently? Sounds like you have a marginally charged or bad battery. If the battery is good then your alternator may not be charging the battery and may be marginal or bad. Check them with a voltmeter or have them checked by an auto parts store. Good luck. Think it might be my hot wire that runs from the battery to the starter. It is in rough shape do to heat from the manifoldand i think it's grounding out. Have a new one that i wrapped in heat tape. Going to finish changing it in the morning will keep u posted.
norcalz28
Jan 16, 2017 03:37 PM
WTR388
Oct 31, 2015 08:31 AM
mephizto
Oct 14, 2015 05:16 PM
charlie1011
Oct 11, 2015 02:26 PM
HoosierinWA
Oct 8, 2015 12:33 PM
