89 2.8 mpfi idles erratically
Old Jan 22, 2016 | 08:11 PM
cowboysfan20's Avatar
I have an 89 rs 2.8 mpfi. It will run fine for awhile and then the rpms seem to be all over the place and will cut off. After a few trys and some gas peddle pushing it runs fine ither then the cel flashing while driving. I can usely tell when it's about to act up by the flashing cel. Theres no routine to it sometimes it won't di it. When it is not running right i can turn the ignition on not running and it will flash codes like the A&B aldl and jumped together. Has any 1 had this problem. Any help would be greatly appreciated. P.S. can a bad MAF sensor cause all the craziness
Old Jan 27, 2016 | 05:25 AM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
Re: 89 2.8 mpfi idles erratically
Have you checked for codes since the light comes on?
mjdavis68
Apr 17, 2016 06:36 PM
Buickstaged
Jan 23, 2016 09:56 AM
84LsxZ28
Jan 20, 2016 07:00 PM
ldentle
Jan 17, 2016 11:08 PM
jorgeblancojr
Jan 17, 2016 06:28 PM
