Maf questions+other cel codes
Old Jun 2, 2016 | 06:17 PM
SOHC-FTW's Avatar
Car: 86 T-top firebird/Black Dodge Ram
Engine: 2.8
Transmission: Automatic
Axle/Gears: 4.10s soon enough
Ok first things first I've done the following...
Plugs.
Fuel filter.
Maf relay.
And tried a buddy's used maf.
I'm getting codes for egr (It can be blocked off correct?), 02 sensor, 33&34 maf codes. Now after all this I still have a fish bite of a miss under a load crappy idle so low it'll kill it self (which smoothed out real decent after used maf and relay but went back after test drive/warmed up) harder restarts. I've checked both power wire and ground with a test light at the maf an the relay and I am getting juice on both, now how do I check the maf itself? I tried a dmv and got nothing (I'm no electrician not even sure I had it in the right sitting) can someone point me in the right direction what setting for dmv do I need to be on, what wires to prob, and what is a good healthy maf suppose to read under throttle and off.
I just picked this 86 up a week ago, it did buck real hard coming up the mountain but now after these things it runs a bit better, I'm just trying to get it running right before i start my resto mod on it I'm a body man not real good with wiring or electric stuff so I'd appreciate all the help I can mustard.
Old Jun 3, 2016 | 03:25 AM
Kingtal0n's Avatar
Car: 5.3L turbo 2800lbs RWD
Transmission: 4l80e
Axle/Gears: 3.512
Re: Maf questions+other cel codes
Not sure if this will help but
a MAF sensor is very delicate/sensitive to flow. The path air takes through it must be straight, without turbulence. If you have modified or altered the OEM path the air takes through a MAF you may have disturbed it, and that can cause many fuel issues, stumbing, idle problems, power problems, anything is possible. You need a relatively straight tube on both sides of the maf sensor, and keep it away from turbochargers and throttle bodies where airflow is more likely to be disturbed.
Old Jun 3, 2016 | 06:16 AM
SOHC-FTW's Avatar
Engine: 2.8
It's an oem intake and paper filter
Old Jun 3, 2016 | 09:27 PM
SOHC-FTW's Avatar
Engine: 2.8
And bumparoo
Old Jun 5, 2016 | 12:55 PM
SOHC-FTW's Avatar
Engine: 2.8
Just gonna block the egr, but since I can't find a direct way of testing the maf I guess just replace it...? It ain't like it would hurt being 30yrs old.
Old Jun 5, 2016 | 10:55 PM
ktthecarguy's Avatar
On Probation
Car: 88 Camaro vert/86 SC
Engine: 355 tbi/2.8 V6
Transmission: 700R4/T5
Axle/Gears: 2.72 posi/3.42 open
Hi there,
I had similar problems. I bought a used MAF, supposed to be good, it was also bad. I got a new one from Rock Auto, now code 34 is gone, and nice smooth idle.
Old Jun 7, 2016 | 02:35 PM
SOHC-FTW's Avatar
Engine: 2.8
Yeah I'll probably go with a new maf...
Had a few mins waiting on things to dry at the shop, so I made a block off plate for the intake manifold and plug welded the egr port on the exhaust manifold. Now all the junk egr is gone.
Sean Brereton
Sep 28, 2023 10:04 PM
SteelheadBen
Jul 31, 2016 10:49 PM
thebossmanscot
Mar 27, 2016 11:11 AM
Titan1833
Mar 27, 2016 03:11 AM
krisb410
Mar 17, 2016 05:51 PM
