Where to start here...
So the car is a 92 camaro with the 3.1 everything is stock and most of it is original.
I recently replaced the fuel pump and filter, plugs cap rotor ignition module and coil. I was driving down the freeway and it just dies and wouldn't fire up for about an hour (was cranking great the hole time) so i got it started drove home and now it again wont start. I plan on Pulling the codes here soon, other than that where should i be looking
Engine: 3.1 V6
Axle/Gears: No idea
Re: Where to start here...
most likely a fusible link. does it/ did it cut off over a bump? mine would stall and would restart fine a whole bunch of times. needlessly bypassed vats.
Car: check
Engine: check
Transmission: check
If the engine still has the original Multec injectors they are likely bad. The coils short out preventing the ECM from firing any of them. Gets worse with a hot engine.
RBob.
RBob.
