v6 tire pressures ?
Old Feb 26, 2017 | 10:16 AM
zs&tas's Avatar
Car: 88 T firebird
Engine: 2.8
Transmission: t5
v6 tire pressures ?
I don't know what pressure I should be at on stock 15" . Can't find the info in my manual and the door stickers all worn away and flaky.
I just checked with a gauge and I am at 26 psi at the moment. It feels quite bouncy the ride and I am wondering if that could be the culprit.
What tire pressures are you running ?
Old Feb 27, 2017 | 06:18 AM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
Re: v6 tire pressures ?
I want to say I was around 30-32 when I had mine for daily driving back when I had it.
Old Feb 27, 2017 | 07:04 AM
zs&tas's Avatar
Car: 88 T firebird
Engine: 2.8
Transmission: t5
Thanks, i have put 30 in her, ill see how it goes
Old Mar 8, 2017 | 04:42 AM
HitchDav's Avatar
Car: 1992 Firebird
Engine: 3.1 l V6
Transmission: Automatic
Here's a quick formula I had found recently you can use for any tire.
Pressure= (Vehicle Weight * 1.1)/(Tire max load * 4) * (Tire Max Pressure)
That 1.1 is in there just as a safety factor by adding 10% weight, should account for typical carrying loads. Useful if you ever switch from the stock size for any reason.
