Ignition Switch?
Car: 92 Z28 Clone
Engine: Vortec 350
Axle/Gears: 3.23 Torsen
Ignition Switch?
When my car is cold, starts first turn of the key. But when hot nothing happens. I have to get out and jump the terminals on my starter and starts first try. So I know its not a voltage problem. ignition switch maybe?
Engine: 3.1 V6
Axle/Gears: No idea
Re: Ignition Switch?
if when its cold, when it starts up right away, can you turn it off and back on right away? same for when its hot.
On Probation
Car: 88 Camaro vert/86 SC
Engine: 355 tbi/2.8 V6
Transmission: 700R4/T5
Axle/Gears: 2.72 posi/3.42 open
Hi there,
maybe heat-soaked starter solenoid? Any click when you turn the key? Very common problem on big-block v8s, possibly on v6s as well.
