Engine Issues
Engine Issues
On my 83 camaro 66k mile 2.8 v6 5 speed, it has an issue between 1k-2500 rpm where the engine stutters while driving. Recently rebuilt the carb (varajet). New spark plugs and wires. In neutral and anywhere above 2500 rpm the engine runs fine, part throttle or w.o.t. But in that range, the best way I can explain the feeling is if you were to punch the throttle and let off three or four times real fast. It isn't clutch slippage causing this. Any help would be greatly appreciated!
Transmission: 4L80E/4L80E
Re: Engine Issues
I'm thinking you're more likely to get help from the V6 guys than the Carburetor forum guys.
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Re: Engine Issues
Re: Engine Issues
If you are absolutely sure that the carb was rebuilt correctly, then it could in fact be vacuum, or even timing related. If you use the process of elimination, you will eventually find the culprit. Be sure your coil and ignition module are in good working condition. First, pull the EST bypass and confirm your base timing is correct. If it is, then re-connect the EST bypass wire. Pull the plugs, make sure they are gapped correctly, check the wires and make sure they are not arcing meaning check for any cuts in them and be sure the firing order is correct. If this doesn't take care of it, then let the engine idle, and lightly spray carb cleaner with the engine idling in key areas to check for any vacuum leaks. If you have no vacuum leaks, then move on to the carb's choke setting and accelerator pump...
Re: Engine Issues
