Soon as I put a new plug in and start it up it gas fouls it instantly I put new fuel pump in all new injectors cap button rotor plugs and wires its only fouling number one cylinder could it be a valve issue
Hmm, def getting spark ? Check you injector wiring. Might have to pull the injector and check it .
just cause stuffs new doesn't mean it works .
okay I'll check it out tonight and repost thanksOriginally Posted by zs&tas
Hmm, def getting spark ? Check you injector wiring. Might have to pull the injector and check it .just cause stuffs new doesn't mean it works .
Quote:
found the problem it had a stuck exhaust valve. ThanksOriginally Posted by strader700
