Less oil from 2.8 V6 distributor leak
Old Aug 18, 2017 | 10:44 AM
W.E.G.'s Avatar
Car: 88 Sport Coupe Camaro
Engine: V6 2.8
Transmission: Borg-Warner T-5
Axle/Gears: RPO/GU6: 3.42
Replacement of distributor with Autozone product seems to have lessened the leak.
This is all there was from overnight after yesterday's 5-mile test drive. Hoping most of it was from residual oil on motor and undercarriage from before the distributor replacement.
Drove it on a much more substantial run today. Not seeing any dripping when stopping in Africa-hot parking lots.
Still idling rough when warm. Cut off a couple times at stop signs when fully hot. May have timing a wee bit too far advanced. Also going to triple-check to make sure vacuum lines are secure when the heat index gets below 109.
Sent from my iPhone
Old Aug 18, 2017 | 11:42 AM
Bob88GTA's Avatar
Car: 88GTA
Engine: 5.7TPI
Re: Less oil from 2.8 V6 distributor leak
Do you have the gasket installed??
Old Aug 18, 2017 | 12:40 PM
W.E.G.'s Avatar
Engine: V6 2.8
Yes.
The new distributor came with a new gasket already installed.
Attached Thumbnails Less oil from 2.8 V6 distributor leak-autozone-distributor.jpg
