V6 electric cooling fan switch
Car: 88 T firebird
Engine: 2.8
Transmission: t5
Hi guys , how is my 1988 2.8 electric fan switched on/ off ?
can i adjust or change sensor so it comes on earlier ?
thanks.
thanks.
Car: 1998 Camaro Z28
Engine: 6.0L
Re: V6 electric cooling fan switch
You'd have to burn a new chip for the ECM. It's controlled by engine temp. I had a toggle switch wired in to my car so I could switch it on/off when I wanted to, if I was sitting in line at the drag strip waiting or stop/go traffic.
Car: check
Engine: check
Transmission: check
The one for a '89 TTA turns on at 100°C/212°F. Just double check first that it has the same threads. Note that there are other temperature switches with other turn on temperatures.
RBob.
On Probation
Car: 88 Camaro vert/86 SC
Engine: 355 tbi/2.8 V6
Transmission: 700R4/T5
Axle/Gears: 2.72 posi/3.42 open
Hi there,
Rodney Dickman has Fiero parts for the V6, and has a switch that works for our V6. Needs a 180F thermostat, though.
Link:
http://rodneydickman.com/catalog/pro...roducts_id=235
Link:
