Size of motor mount bolts?
Old Oct 7, 2017 | 06:35 AM
W.E.G.'s Avatar
Car: 88 Sport Coupe Camaro
Engine: V6 2.8
Transmission: Borg-Warner T-5
Axle/Gears: RPO/GU6: 3.42
Anyone happen to know the sizes of (or source for) the bolts? Easier to get them in advance so I don’t have to crawl out from under the car, and go shopping, in the middle of the job.
Old Oct 7, 2017 | 03:04 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Re: Size of motor mount bolts?
The bolts that fasten the mount to the K member should be a standard 3/8" bolt. The through bolts should be 7/16" standard.
Old Oct 7, 2017 | 09:57 PM
W.E.G.'s Avatar
Engine: V6 2.8
Thank you.
Would it be correct to assume the 7/16 are not threaded for the portion of the bolt surrounded by the rubber portion of the mount?
If anyone knows the overall length of the bolts, I’d be much obliged.
Old Oct 8, 2017 | 09:36 AM
Tibo's Avatar
Car: 1991 Z28 Vert
The through portion of the bolt is not threaded.
