Megasquirt2 ecm
Subscribe
Nov 27, 2017 | 08:19 PM
Okay so im ditching the stocker ecm finaly since i can do better the ms2 is ordered and on the way i was wondering if any one could set me up with a base tune to help get the car running.
Its a 3.1/3400 hybrid
bored .04 over
delta 272 cam
gt3852 turbo
and some ls1 style valve springs
any other info needed i will be able to give
all help is very appreciated lol excited to have this beast on the road and drive around base
Reply 0
Nov 27, 2017 | 08:57 PM
Re: Megasquirt2 ecm
The base tune it comes with is all I've ever needed.
Reply 0
Nov 28, 2017 | 02:40 PM
Re: Megasquirt2 ecm
Quote: The base tune it comes with is all I've ever needed.
I ordered it from DIY as a pre built unit. So they ship them with default inputs and i shouldnt even have to touch them?
if so thats pretty dope saves me alot of time
I also have 60lb injectors idk if that changes anything idk really what ur running bit ill take your word for it
Reply 0
Nov 28, 2017 | 06:13 PM
Re: Megasquirt2 ecm
No, you will need to set up the basics, Required fuel, ignition type, etc. The base maps have always allowed me to at least start the engine and start the process of tuning though.
Reply 0
Dec 2, 2017 | 10:03 AM
Re: Megasquirt2 ecm
Quote: No, you will need to set up the basics, Required fuel, ignition type, etc. The base maps have always allowed me to at least start the engine and start the process of tuning though.
personaly what have you found to be the easiest in terms of tunning with the megasquirt system? What habits do these motors tend to exhibit?
Reply 0
Dec 3, 2017 | 12:18 PM
Re: Megasquirt2 ecm
I don't understand your questions.
I just start tuning the same way everyone does, set basics, get fueling acceptable, and adjust fuel and timing as necessary.
Reply 0
Subscribe
