Replace water now car will turn over but wont started
Old Mar 4, 2018 | 12:27 PM
Amere872's Avatar
Want a title? Post!
1982 camaro z28 replace water pump now car turn over but wont started
Old Mar 5, 2018 | 08:26 PM
LiveIt!'s Avatar
Car: 1988 Camaro Sport Coupe
Engine: The All-Powerful 2.8l!! :P
Re: Replace water now car will turn over but wont started
What's harder to diagnose is how you got a V6 in a Z28
Let's get the basics first, does the car have spark? Was timing messed with any?
Old Mar 6, 2018 | 07:04 AM
RedLeader289's Avatar
Car: 1983 Z28
Engine: 385 Fastburn
air, fuel, fire. You're missing one (or more).
Air: Assuming your intake isn't completely stuffed with a mouse house, you have air.
Fuel: When you turn the key listen for the fuel pump, look down the carb and see if fuel is spraying when you work the throttle.
Fire: option 1 - connect a light to one of the posts on your distributor(hot wire to the post, ground to the closest ground). If it lights up while you're cranking you have spark.
option 2 - pull spark plug #1 and leave connected to it's wire, have a gullible friend hold onto it while your crank. If they jump and say some choice words, then you have spark.
ttruelove
Mar 24, 2018 03:30 PM
Jackrabbit501
Aug 23, 2017 10:59 PM
jbradshaw77
Apr 28, 2017 01:44 PM
serioussam1212
Oct 31, 2016 05:34 PM
Alberocks
Oct 9, 2000 03:33 PM
