Ok found somting interesting, Help...
Old Jan 5, 2002 | 07:35 PM
Kj Rockz's Avatar
From: Mililani, HI USofA Search Posts: 2848.............. Whore Posts: 47.................. Magical Whore Posts: 1
Car: 91 Camaro 77K
Engine: 3.1 Vslick
Well first off, I started with the wires cap and rotor, All look like Sh*t, that is probably contributing to my problem.
Problem two, I pulled out plug number 4, and it had oil on it. Whats up with that? Is that good bad? What could cause that.
I workin on it right now
Old Jan 5, 2002 | 09:17 PM
fiream's Avatar
Car: 1983 Pontiac Firebird
Engine: 400HP 350
Two words, Blow Bye, you need to rering the cylinder or it may also be your valve stem seal.
Old Jan 5, 2002 | 09:30 PM
Kj Rockz's Avatar
Car: 91 Camaro 77K
Engine: 3.1 Vslick
Huh?
Old Jan 5, 2002 | 09:34 PM
BitchinRS's Avatar
Blow-bye, iis when oil is blowing passed the piston. uasaly caused by worn rings
Allthough you may what to check your valve covers. I had a small leak coming out of my valve cover and it was dripping down and gettign into the chamber by speaping passed a lose spark plug.
Old Jan 5, 2002 | 09:43 PM
Black 86 'bird's Avatar
Car: 1986 Firebird, 2000 WS6
Engine: 2.8, LS1
Transmission: 700R4, T-56
Axle/Gears: Stock, Stock
Took the words right outta my mouth
Old Jan 5, 2002 | 09:45 PM
Kj Rockz's Avatar
Car: 91 Camaro 77K
Engine: 3.1 Vslick
Is this somting bad that needs to be fixed?
Old Jan 7, 2002 | 04:11 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
It's not bad, per say... it's not great, but your engine's not about to break. It's just burning some oil. Valve seals usually all go at once; and their burnt oil is just at startup (oil drips into the cylinders while the engine is stopped, so you get a puff of blue when you start the car). I bet if you bought a $25 compression tester (with the hose, not the pain-in-the-*** "stick it in the spark plug hole" $15 tester), you'd find that's the cylinder with the lowest compression out of the bunch.
hectre13
Dec 11, 2023 08:14 AM
gta90
Sep 15, 2015 04:00 PM
overdriv
Aug 20, 2015 03:52 PM
bjpotter
Aug 12, 2015 06:06 PM
antares57
Aug 6, 2015 07:47 AM
