Radiator cooling fan fuse location
Old Jul 19, 2018 | 08:42 PM
MajorLeauge's Avatar
Car: 1988 Pontiac Firebird
Engine: 2.8 L v6
i need to find the fuse for the rad cooling fan because i could not find a diagram and it's WAYY too hot here in Utah to be messing around with my car looking for a fuse. -MajorLeague
Old Jul 20, 2018 | 06:14 AM
OrangeBird's Avatar
Car: 1989 Firebird
Re: Radiator cooling fan fuse location
Here is the wiring diagram for your fan , the detail you seek is in the lower left of the diagram . You will see that the coil side of the fan relay is protected by a 20 amp fuse that's in the fusebox and labeled "fan" . The high current switch contacts of the relay that actually feed the fan motor it's power are protected by the fusable link called "rust" , but that link also feeds other circuits so if that was open other things in the car wouldn't be working as well . With this diagram and a voltmeter you should have no problem tracking down why the fan won't run , it'll be either the fuse , the relay , the fan motor itself , or the wiring connecting all those items together .
Also , just as a point of general information here , your user profile listing your car as a "Formula 350 with a 2.8 V6" is either mistaken , or your car suffered one Hell of a downgrade swap sometime over the years because there never was a factory built Formula 350 with a V6 !
Either someone swapped out the 350 8 cylinder for a V6 , which is very HIGHLY unlikely , or , someone slapped Formula 350 badges on a V6 car , which is the most likely reason for the wrong model/wrong engine confusion . Remember , the "Formula 350" designation means the car was supposed to have been factory built WITH the 350 8 cylinder , hence the "350" in the model designation . You may want to correct this misinformation so that in the future when you ask questions , the people who answer will know exactly what you've got .
Attached Thumbnails Radiator cooling fan fuse location-fig34_1988_2_8l_engine_wiring.gif
Old Jul 24, 2018 | 11:11 AM
OrangeBird's Avatar
Car: 1989 Firebird
BUMP
Old Jul 24, 2018 | 02:07 PM
OrangeBird's Avatar
Car: 1989 Firebird
BUMP
Old Jul 24, 2018 | 10:15 PM
Engine: 2.8 L v6
thanks for the reply. I'm new to third gens, mistook for a formula 350, thanks for the correction.
Steve86TA
Nov 24, 2006 08:02 AM
Steve86TA
Exterior Parts for Sale
Oct 29, 2006 02:12 PM
Steve86TA
Oct 29, 2006 02:10 PM
Steve86TA
Oct 29, 2006 02:08 PM
TravisZ28MAXX
South East Region
Nov 16, 2003 06:43 PM
