Stalling problems........
Old Jan 11, 2002 | 03:47 PM
Kevin S's Avatar
Everytime I stop,the damn car quits.When it is cold I have no problems.Just when the car is at operating temps and the idle drops to 750rpm it acts like a miss then the car quits.It's very,very,VERY nerve racking.
Since it has started,I've replaced the plugs,filters(air and fuel),a dead fuel pump and the IAC.
I have raised the idle to help.That didn't help at all.Adjusted the TPS.Nope...no good.
Someone said my plug wires could cause this but I don't see how plug wires would only cause a miss at idle.
Anyone have any clues?
Old Jan 11, 2002 | 03:56 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
How's the timing?
Old Jan 11, 2002 | 04:04 PM
Kevin S's Avatar
The timing is good.
Old Jan 11, 2002 | 04:31 PM
TFM4th's Avatar
Car: 87' Firebird
Engine: 2.8L
Transmission: Standard
my firebird had the same problem your having it was also jumping when i started to take off, i brought it to my mechanic and he took off my catalatic converter and looked inside, the entire inside was smashed apart pieces everywhere. i replaced it and it worked perfectly
Old Jan 13, 2002 | 02:23 PM
Kevin S's Avatar
I know it isn't my cat.It's gutted.The only item I have left to try is plug wires.
Old Jan 13, 2002 | 03:15 PM
dsaint1347's Avatar
I had the same problem a while back, it turned out to be my EGR was acting up. I took it out clean it replaced the gaskets and so far no fail code, but then again it's been pretty cold here so I am crossing my fingers. my car died while going at idle
darwinprice
17
Oct 11, 2015 11:51 PM
HoosierinWA
Oct 7, 2015 10:15 AM
Jlanz55
Sep 29, 2015 08:55 AM
lanceflame44
Sep 25, 2015 12:28 PM
amcnellis
Sep 16, 2015 04:16 PM
