Lubed a speedo cable this weekend...
Old Jan 14, 2002 | 01:28 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
...and it looks like it worked. It was an '87 Camaro. I had to undo all the Torx screws holding the dash faceplate on, then undo the small hex scres holding the dash "glass" on, then undo two small hex screws holding the dash's metal "gauge bezel" on. I removed two 10mm "fake nuts" from the bottom corners of the dash, right near some light bulbs. I popped the quick-disconnect lever for the speedo cable using a long screwdriver from underneath the dash. (The lever's on the bottom of the cable, and is part of the speedometer. Push the lever in, pull the gauge cluster out of the dash, and it breaks free.) Then I adjusted the steering wheel to bend as far down towards the floor as possible. I twisted the gauge cluster so the gauges pointed downward, and pulled it out at the same time so the cluster was horizontal above the steering column. Then I pulled the cluster out from between the wheel & dash top via the driver's side of the steering wheel.
Then I started pulling the cable out of it's sheath.. I pulled and pulled, twisting as I pulled, and wound up with a short 2 foot cable.
Someone replaced the one-piece speedo cable with a two piece. (No, the car doesn't have cruise control). The joint under the hood (below the brake booster) was rusted solid; I couldn't break it free. So I reinstalled the cable. I squeezed a glob of Silicone (Napa, "Sil-Glyde") into my hand, and as I pushed the cable back into the sheath, I ran the cable thru the glob to lube it. I twisted the cable as I reinstalled it. I used a q-tip to remove any trace of silicone lube from around the blue tip of the speedo cable- that's the piece that goes to the speedometer. The blue tip should seat all the way into the end of the cable sheath. If it doesn't, twist the cable and push it into the sheath so it seats.
Anyway, the speedometer seemed to be smooth; he might not need that second part lubricated. We'll see! I have to make a note tho- his car only has 112,000 miles on it. Mine has more than double that! I think I'll lube the speedometer cable this spring.. my speedo's been a bit jerky; I always thought it was supposed to be like that! (The jerkiness is the unlubed speedo cable hitting the cable sheath)
Old Jan 14, 2002 | 05:53 PM
Brian K's Avatar
Glad to hear it went easy...
Old Jan 15, 2002 | 09:42 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I actually took a few pictures of the dash gauge cluster removal; when the 'ol webpage goes up, I'll put them on (in case anyone needs this for the future)
Z28/ZR1
Oct 23, 2015 01:04 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
