I need some polished Headers for a V6 2.8L MPFI
Pontiac Firebird..where can I find it??
midias
close
About the best you will be able to find are ceramic coated pacesetter headers
https://www.summitracing.com/parts/psm-72c1209
Thanks, but I believe that one you send me was a 3.8L..it's hard to find a 2.8L.. but II would check Summit Racing..Originally Posted by midias
About the best you will be able to find are ceramic coated pacesetter headershttps://www.summitracing.com/parts/psm-72c1209
I think a Camaro or and S10 would fit..since it's the same motor.. I would keep on serching..
^You're correct, that link is for the 4th gen's V6, the link below is what you're looking for for your 2.8.
https://www.summitracing.com/int/par...model/firebird
Thank you.. I think that's the one, I also found pacesseter web page Headers but it's the same Summit Racing it's selling..Originally Posted by pg29
^You're correct, that link is for the 4th gen's V6, the link below is what you're looking for for your 2.8.https://www.summitracing.com/int/par...model/firebird
thanks again!!
