1986 2.8 replaced injectors, now shudders at idle and has less power...
Old May 2, 2020 | 03:48 PM
BackInBlackGP's Avatar
Car: 1986 W69 Special Edition
Engine: 2.8/ECM/Int/Exh
Axle/Gears: 3.42 posi
Howdy all. Decided it was time to replace the 30+ year old MFI injectors with a flow matched set of Bosch disc type with the same flow rate as the stock Delco ones. Now the engine appears louder through the exhaust, and it drives as if only on 5 cylinders. Idle is rough. I tore apart the intake again and checked the injector coils, all which were around 16.7 ohms cold. Stock ones were around 16.2 ohms. I don't see anything obvious, and I've triple checked all of my wiring, vacuum lines and bolt torque. Likelihood of a clogged injector? Trying not to have to tear it apart too many more times, as it's hell on my back leaning over in the bay...
Thanks for any and all input!
Old Jun 22, 2020 | 06:31 PM
85Z28NOS's Avatar
Car: 85 Camaro
Engine: 454 RamJet
Transmission: LT1/T56
Axle/Gears: 8.8w/4.10
Re: 1986 2.8 replaced injectors, now shudders at idle and has less power...
I just ran into similar issue after replacing my factory injectors with some rebuilt ones. engine stuttered at idle and stumbled if tried to drive. Replaced them again with a set of Bosch and car runs great again! I should mention I had replaced the cap, rotor, plugs and wires when I replaced the first set of injectors so I knew spark wasn't my problem
Bazookajoe254
Jul 20, 2007 11:40 AM
327_TPI_77_Maro
Oct 12, 2006 10:30 AM
iroc240_3
Jul 10, 2006 07:24 PM
H-BOMB
Nov 23, 2005 08:14 AM
chevyboy07 91
Dec 2, 2003 07:21 PM
