Need help 86 2.8 manual DEAD
Old Jun 5, 2021 | 01:37 PM
C_GUCCI's Avatar
Car was running decent, not great, choked and died leaving a stop like the alternator had gone but months later it still had power. Got it back home and when I tried to turn it over it wouldn't even kick the starter. I've read through the haynes manual and can't seem to find any reason for it. I'm assuming it's a fuel air ignition problem but I am completely stumped where to start on this thing. Any help would be greatly appreciated.
Old Nov 22, 2021 | 08:59 PM
Bobby Suth's Avatar
Car: 1990 firebird,1989 Iroc z,1986 fire
Engine: 3.1lt,5.7tpi,3.1mpfi
Transmission: auto,auto
Axle/Gears: 273?277
Re: Need help 86 2.8 manual DEAD
Check and make sure battery is fully charged. Make sure starter is good. Check all connections and fuses. See if you can turn it over manually.
Old Nov 23, 2021 | 12:00 PM
1989karr's Avatar
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
" died leaving a stop like the alternator had gone but months later it still had power. Got it back home and when I tried to turn it over it wouldn't even kick the starter. "
Kinda confused about that statement,
but first thig to do is see if your battery has 12 volts
evilemokid94
May 8, 2011 05:23 PM
Oddball
Dec 28, 2003 03:13 PM
Monkie
Jun 15, 2001 01:46 PM
