fuel injectors ticking ????
Old Jan 25, 2002 | 09:20 PM
WaynesRS's Avatar
Well I just got done changing 7 vacumn hoses on my car .I have not driven it yet , but it seems to idle a little bit better .I've been hearing this ticking which sounded like an exhaust leak for a couple of weeks now .Well I finally found what the ticking is with my stethascope .I think its the fuel injectors . ? Can the injectors be seen through the holes (gaps) on he plenum . I stuck my stethascope through one of the gaps and put the end on what looked like an injector or the top of one and found the ticking .I CAN'T BELIVE I've finallly found the ticking !!! I've been looking for it for a couple of weeks now !!!!! But , is this the injector , or injectors ticking ?
Old Jan 25, 2002 | 09:25 PM
Camaro_hunter_d's Avatar
You may be hearing the one open/close. But they don't "tick" persay, at least I have never heard them tick. Now you may be hearing a small arc to ground from one of the injector harnesses.
But to answer one of your questions you can see the body of the injector on the other side that you were looking. IE standing on drivers side you should be able to see 2 of the passenger side ones & vise versa. Depending on the thickness of the stehoscope you could be able to get the same side injectors...
Old Jan 25, 2002 | 11:01 PM
WaynesRS's Avatar
Thanx Hunter ! ...If one of the injector wires is arcing if I tape it with electrical tape will that make it stop ticking ? .....At first this ticking was just on one side of the motor .Today was the first day I started hearing it on both sides .But it seems like its worse on the drivers side , but it started on the passenger side and can still be heard on the passengers side also .
Old Jan 25, 2002 | 11:28 PM
Well I shoulda asked this before.. But anyway
Is it running kinda funny, kinda like stutering? a light hesitation? thats intermitant? if its doing that then its arcing off.
And yes E tape (electrical) will fix.
Old Jan 26, 2002 | 08:22 AM
WaynesRS's Avatar
Yeah , its running just how you described . Thanx again ! ...Hey when did these fellas show up ? :hail: :lala:
I give everyone on this board a big for helping me ! If it wasn't for you guys I might be acting like this : :hail: ,,,lol
Old Jan 26, 2002 | 12:56 PM
It will be easiest to take the upper intake off to get to the injector harness. Look for bare wires at the plug. If theres even a slight shine tape it. TAPE EACH WIRE INDIVIDUALLY not in a group. If You tape in a group the wire may arc to another wire.
And hey thats what I'm here for right?! :lala: :rockon:
Old Jan 26, 2002 | 03:37 PM
CaliCamaroRS's Avatar
Engine: LH0 3.1L
Never heard them tick?? You obviously haven't heard many injectors. If you put your finger on one you can FEEL them tick.
Old Jan 26, 2002 | 04:55 PM
No actually I have dealt with many an injector. I have heard some noisey ones but they were close to 18 years old. I have never heard a Multec type injector make any noise unless it was getting ready to fail. His car is continuing to run and I can distinguish between an arc and a very weak tap. And you do not "feel" them tic you feel them open and close. If the tolerances are out too far then it colides internally. NOT a good thing.
Old Jan 26, 2002 | 08:54 PM
85SportCoupeto89RS's Avatar
Car: 85 Camaro SC
Engine: V6
I work with injectors alot a work flowing and matching up sets for motors.They tick when they open and close, they sound like a wind up toy.But I use to hear a ticking noise from the inside of my Camaro, I had a cracked head on my 1 cylinder spark plug.The crack went all the way up the threads any would make a ticking noise when ever it fired.Hopefully you dont have a cracked head.
Old Jan 26, 2002 | 11:11 PM
grumpygreaseape's Avatar
Car: 85 iroc,96 z28,96 Ram 2500,69RR
Engine: 383 with AFR heads.
Transmission: richmond 5 speed
Axle/Gears: 1991 w/1LE.auburn pro series.2.73's
fella,fellas,fellas-here please allow me to let you all in on some tech. trivia-injectors are made to function "pulse" by our ecms via a circuit that grounds the circuit each time the injector(s) is called upon to do its duty. on the other end of the circuit is 12v switched current.if you were ever to hear a inj.power wire "arcing" to ground-which you never will-it might be heard once, then the ecm fuse(s) go byebye or it just takes out the power transistors whose duty it is to switch the current on and off thru ground as required. what you guys are listening to is the injector working. inside it is a pintle moving up and down in a magnetic field created by the 12v in and the ecm on the ground side. now there may be a ticking noise but it aint the injector wires arcing. hope i helped out
Old Jan 27, 2002 | 01:52 AM
Engine: LH0 3.1L
Jesus H. Christ, Pyle. Yes you "feel" them tick because the opening and closing CREATES a ticking sound/ pulsing feel.
Old Jan 27, 2002 | 08:38 AM
89BlackFBird's Avatar
I heard that ticking sound on my firebird. But its only when the engines cold so Im pretty sure its a oil pressure leak, or some sort of vacuum leak but Im not really to worried about it right now but if someone could confirm it to be a oil pressure leak I'd be grateful. Thanks
Old Jan 27, 2002 | 09:03 AM
WaynesRS's Avatar
Thanx alot guys .Yeah , I could be just hearing them tick when the motor is cold . Im ganna pay more attention to it today .But its a loud tick when the motor is cold .
Old Jan 27, 2002 | 09:07 AM
Yeah mines pretty loud when its cold. Especially when its revved. Im gonna check it out today. Im gonna order my 2030 crane cam 2day 2, along with new tires. Thinkin about Firestone Firehawk SS20s, maybe if the weather gets better in a few weeks I'll register it and get it out.
Old Jan 27, 2002 | 09:34 AM
I Cant Drive 55's Avatar
My1997 3.1 lumina injectors do tick especially when cold . I took it to the chevrolet dealership because I wanted to make sure there wasnt a problem. The ASE CERTIFIED general motors technician told me it was the injectors ,and it was very common in the 3.1 MPFI . A couple months later my in-laws bought a 3.1 lumina that was a year newer than mine , and sure enough it had the same ticking noise.
Bottom line:injectors do tick.
BTW my firebird ticks also just not as loud.
Old Jan 27, 2002 | 11:28 AM
Well I quess I am fortunate to have never had a "ticking time bomb" injector in my life.
Old Jan 27, 2002 | 08:31 PM
Have you ever had your hearing checked
Old Jan 27, 2002 | 08:55 PM
nah-you can check that oil yourself-any old boy can do this test if the need arises-first step consists of driving the vehicle until the light comes on or the gauge confirms zero oil pressure, the second (most important) step requires you to verify that the indicators are functioning as intended-continue driving with a slightly heavy foot for -this is critical-at least 10 miles. somewhere along the way while performing the 2nd step your oil pressure leak diagnosis will be completed. hope that i can help. really
Old Jan 27, 2002 | 09:13 PM
Hmm Lest see.. I was in the Navy for 2 years so yes My hearing is quite good. Dip ****. I have had my car for almost 3 years now. Neither me nor any of my friends have EVER heard it "tick". I had a friend in the Navy with a 92 'bird with the 3.1, His did not "tick" either.
Old Jan 27, 2002 | 09:43 PM
camaro hunter-you can believe him-they do tick, some louder than others, but "tick" they do.
Old Jan 28, 2002 | 07:03 AM
86Chicken's Avatar
My 2.8s tick but I usually can't hear it over the sound of the engine. The injectors on the family Buick 3.3L are really loud when cold.
It is normal for solenoids/relays/injectors to make a little noise.
Dale
Old Jan 28, 2002 | 09:30 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
LOL! This has got to be the funniest message thread yet. Injectors tick/click/whatever; they're not silent.
Old Jan 28, 2002 | 09:35 AM
Engine: LH0 3.1L
Hey Tom, maybe those non-ticking injectors are what gets Hunter 30 mpg city........I should pick up a few. :hail:
Old Jan 28, 2002 | 12:09 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I have a set in my basement; they're not hooked up, so they're not ticking. Maybe if I carry them in the back seat, I'll get more performance...?
Old Jan 28, 2002 | 12:50 PM
WaynesRS's Avatar
Backseat ? Id put them on the drivers seat ! Ya might run in the 12s then ! .....Im not too concerned about the injectors anymore .They sound like they are ok to me besides needing a good cleaning .Yeah , I know tom , send them to rich lol . Actually I think they are beyond cleaning cus I think they leaking .BUT I have bigger probs now . My torque converter is shaking again . Im in the process of buying one now .I had to cancel one this morning I ordered on jegs lastnight b/c it was a 12 inch and I need a 10 .Im looking for something that is only 300-600 over the stall I have now , a 10 inch one . 30 spline ....Something else I just thought about should I get a lock up or non lockup ? ??
Old Jan 28, 2002 | 04:34 PM
WaynesRS's Avatar
Well this is now one less problem and worry I have now ! I just placed an order with summit for accel injectors .I figured I need to order them while they have them . Now onto the torque converter ! ....also ordered me a B&M super cooler trans cooler while I was at it !
Old Jan 28, 2002 | 10:12 PM
Listen Camaro_hunter d
I was joking ,didnt you notice the smiley faces. You seem sooooo smart on everything else, you couldnt friggen figure that out.
Alot of times I think you are full of BS . I have seen you make many inaccurate technical posts.
I have forgotten more than you will ever know about engines ,so dont call me the dip ****.
Old Jan 29, 2002 | 12:10 AM
Engine: LH0 3.1L
LOL. Lets see.....6 crappy ticking injectors plus 6 perfect non-ticking injectors = 50 MPG!!!!!!!!
Old Jan 29, 2002 | 02:33 PM
hows about carryin em in yer back door.
Old Jan 29, 2002 | 03:54 PM
WaynesRS's Avatar
you'll need wheely bars then cus you will be running in the 10s
Old Jan 29, 2002 | 10:20 PM
you can fit wheelie bars up there too? your the man, er something
bryan623
Mar 22, 2021 06:43 PM
New2Chevy
Oct 4, 2015 11:27 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
kyleb24
Aug 15, 2015 08:24 AM
Firechicken86
Aug 12, 2015 10:07 PM
