V6 perf. parts
Old Jan 29, 2002 | 09:07 AM
snowbird's Avatar
V6 perf. parts
Where is a good place to find 2.8/3.1/3.4 peformance parts? Also, what kind of hp/tq are people getting out of them? Thanks.
Old Jan 29, 2002 | 09:38 AM
Joe_L's Avatar
Car: 1995 Z28
Transmission: Built 4L60E
Axle/Gears: 3.23's - Limited Slip
Heres a few sites to look at:
http://www.engine-parts.com/GMV6/gm28stroker.html
http://www.engine-parts.com/GMV6/28camspecs.html
http://www.crower.com/pdf/19.pdf (Make sure you have adobe)
http://www.cranecams.com/master/apps/chevy1.htm
About the performance gains I am too poor to afford any of these mods, so I do not have any to compare from. But I am sure there are lots of people on this board who can help you out.
Old Jan 29, 2002 | 11:18 AM
Brian K's Avatar
What ever you do, DON'T waste your money ona chip, pulleys, performance plugs until you have:
1. Catback
2. Crane 2030 CAM
3. 1.52 Roller Rockers
4. Coyles Double Roller Chain
5. Nitrous
6. Shift Kit
7. Locker
8. 4.10 rear gears
Old Jan 29, 2002 | 12:06 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Anywhere, really... http://www.summitracing.com is my favorite. Keep in mind you'll never see a part listed for a 2.8/3.1 in their catalogs or on their websites; you have to know how to search for it- or you can do what I used to do, and CALL them. They'll know. Some examples-
Dynomax Super Turbo cat-back #17493 was meant for V8's, but fits our cars.
Holley ignition module #891-103 is sold only for V8 TPI remote-coil ignitions, but the same stock (GM) module is used for both the V8 TPI remote-coil ignitions and our V6 MPFI remote-coil ignitions, so it'll work
Any ignition coil sold for a V8 will fit. And I do mean -any-! Yes, even the MSD Blaster 2 will fit, you just have to modify our wiring harness to take it.
Any rear gears sold for a V8 f-body will fit our 7.5" 10-bolt rear ends.
Any suspension part sold as being for a "TransAm" or "IROC" or "Z28" will fit our cars. (edit- with the exception of a strut tower brace! Nobody's 100% sure of this one yet.)
The adjustable fuel pressure regulator sold for GM V8 TPI motors will fit our cars (same regulator).
Even the K&N filters sold as for Camaro TPI or Firebird TPI will fit the same year of Camaro or Firebird with V6 MPFI. (Ex= 86 Camaro TPI filterS work on an 86 Camaro V6, 88 Firebird TPI filteR (one) will fit 88 Firebird V6 MPFI.)
Etc, etc... plus, do searches on this V6 forum for parts and you're sure to find numbers.
Old Jan 29, 2002 | 03:32 PM
SAEspinz80's Avatar
ahh, yes the STB question. no one is quite sure if it fits....mainly because it has been mentioned the the 60* V6 sits higher than the 90* V8....which makes some sense because 60* is narrower than 90* making the the height a bit higher.....in theory (if that made sense)....anyway....those are all good suggestions, and TomP is right, calling is the best way to go most of the time, and the best way to get answers.
Brian k's suggestions were good.....and IF you have the money, you'll get the biggest bang right away by going that route. Although keep in mind 4:10 gears aren't for everyone, gas milage on the highway will suck, but accelleration off the the line will be tremendous.....thats why many people on decide on 3.42's or 3.73's. just wanted to add my .02 on gearing.
and keep in mind, everyones opinnions on perfomance will differ...decide what you can afford and what your goals are and work from there. I have yet to do the cam....rockers....or shift kit and my car had noticably more power than stock...
Old Jan 29, 2002 | 04:20 PM
V6camaroman's Avatar
try www.pawengineparts.com they have a lot of performance parts for our cars. if you want some pointers look at my signature. i have a lot of mods. im not tryin to be a hot shot but i prolly have one of the fastest cars on the board.
Old Jan 29, 2002 | 04:55 PM
syxx's Avatar
Just not worth it, Pulleys and chip.. Ya want a cam, rockers first..
LT1Formula
20
Nov 14, 2015 12:02 AM
Thomas
Oct 3, 2015 05:34 PM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
1nastygta
Aug 8, 2015 07:38 PM
