20 inch rims
Car: 1990 iroc-z
Engine: 5.7
Transmission: auto
20 inch rims
I was wondering i have a 1990 iroc 5.7 ported stock heads custom grind cam
gears headers and i am runing it with 20 inch irocs and wanted to know how much of a difference 16 inch irocs would make since i have never driven it with the stock rims.
Car: 1990 Camaro
Engine: 355ci
Transmission: TKO-600 5 speed
Axle/Gears: 3.73 10 bolt
i call bs i wanna see pics. If you actually did put 16's or 17's not only would you see an improvement in ride quality and appearance, your car would be a hell of a lot faster because 20" rims weigh a ton. Regardless i still call
on 20's unless i see pics.
on 20's unless i see pics. Senior Member
Car: 1988 camaro z28,1997 camaro lt1
Engine: 355 afr 195 heads,tpis big mouth
Transmission: 700r-4 built by me 3-4 z pack
20 inch wheels will fit i have seen them on irocs will have to hammer the innerfinders in to clear so they will not rub when turning
nice guys....
yes the smaller wheels will make a dramatic reduction in rotational weight freeing up major power. 20's are the worst thing you can do to a heavy car like our own when you want to go fast.
remove a rim/wheel and weigh it before you consider changing sizes. my stock 16's with 245/50/16 pilots weighed roughly 50lbs just to give you a reference. my new 18's are about 40 with tires but they are billet and not cast.
a cast wheel is exceptionally heavy, especially a 20. post some pictures i want to see...
Car: 91 Z28 t/top
Damn.... that's the only set of 20's I've seen that look good...Where did you get'em? I know CustomWheelsMarket.com sells'em here in SoCal-expensive$$$$
obviously not a stock 5.7 motor then or the ls1 was junked. your taking a 220 rwhp car maybe with 20's and racing a 300 rwhp with smaller wheels assumingly. there would be no contest.
anyhow looks good......way to show everyone who thought it was b.s. don't know why anyone wouldn't believe you though as there are quite a few members with them on here. looks good kep it up.
Car: 91 Z28 t/top
Originally posted by 90redz
I paid $1000 for them without tires
only one thing...20's w/o a brake upgrade? are you nucking futs? I know Kandied is sporten' the Baers, but stock these cars don't stop for crap, and you want those dinky 10.5 brakes to stop 20inches of rotating mass? The car does look sharp(suprise to me, not usually a fan of the huge wheels) but set some priorities...seriously, you could put new pads on that thing w/o taking the wheels off...
later, justin...
not trying to be a dick, just my opinion
I know, I know...opinions are like a..holes, everyone's got one..
later, justin...
Car: 1990 iroc-z
Engine: 5.7
Transmission: auto
ther car is not stock it has custom grind cam, stock ported heads,port matched lower intake,T.E.S headers, custom dual cat y-pipe with high flow cats, flowmaster, rebuilt tranny, shift kit and tranny cooler, free mods, wires, blaster coil, 176 fan switch and 3.73 gears
That is a pretty sweet car...minus the rims of course.
Seriously man, your car would be so much faster with a smaller rim. Sounds like you have a decent setup, you must absolutely roast those 20's. Switch rims and be amazed.
Seriously man, your car would be so much faster with a smaller rim. Sounds like you have a decent setup, you must absolutely roast those 20's. Switch rims and be amazed. TGO Supporter
Car: NCC-1701-D (docked in AZ)
Engine: impulse drive
Transmission: fusion reactors
Axle/Gears: Rescued from the Borg by my crew
Wow madbrace!!! Two posts since November of last year and one of them is a smiley with a bs sign. Good work!! Your contributions to this board are deeply appreciated.
Originally posted by madbrace
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
I don't think 20 inch rims and racing should be used in the same sentence, but that's just me.
They do look good on the iroc though.
Car: 87 Black Formula
Engine: Rollercammed Lg4
Axle/Gears: 3.23 10 Bolt Locker
There's a guy in my country with a GTA with 20'ties on it. He says he has them on BECAUSE he's racing it. Well, he puts some 15 inch slicks on when at the strip though, but autocrossing and driving on the street, it's the 20's.
Lets see if I can dig up a pic....
This guy is quite serious, sporting a 540 inch twin turbo setup. Guess he knows what he's talking about when going with 20's.
Car: Camaro Z281991 Engine: 5.7L/350 TPI Transmission: TH700R4 ··································· Car: Acura CL 1998
Engine: 3.0L/183
Transmission: 4 spd auto/OD
I dont see twin turbos in that pic.
The lower profil tire obviously helps, tho like said, The weight
those mags carry shouldnt be beneficial for racing ..
If you are throwing 20" or even 19" wheels on a car that you still want to be fast, then you either need some high HP numbers, or loose a whole bunch of weight, both rotational and sitting
I have 19's on my car and i can still run 12's and i haven't even touched the internal components of the engine
So don't be so quick to say large wheels can't go on a race car.....
Originally posted by Kandied91z
not if he changes the wheels like he says.
oh i absolutely agree.....i don't think a ls1 even with a little nitrous will be bad on the 10 bolt assuming he doesn't run sticky tires. anything above 300 with dr's i'd start to worry, especially if the rear hasn't been maintained.
i wasn't trying to say what you would run, just what i know that combo will run with the similar weight. without nitrous i definately see you at low 13's assuming you can hook. sure we would all love it if they went faster but to get into low 12's and even 11's is cause for some serious power, good traction and good driving.
you'll need to be hitting a very low 60' to pull that off.
Originally posted by 25THRSS
Take it to the track. My guess is a mid 13 or worse.
Who in their right mind would install nitrous and then go to the track and not use it......
.......If i was racing, I wouldn't be racing N/A, so it's completely pointless to post what i would run in the 1/4 without the nitrous....So yes, I can run in the 12's with all 76" of chrome......
I love how people say they'll run this and that when they've never been to the track in the first place.
Maybe if he run's sticky tires out back, which I wouldn't recommend that with a ten bolt anyways. Otherwise you won't hit 12's with a stock LS1. I love how people say they'll run this and that when they've never been to the track in the first place. If he is talking with the nitrous then it is very possible, but I don't see it NA.
had it been a 2.0 60' it would have quite possibly been a 12.99. on street tires, stock. '99 camaro ss m6.
-edit- i also went 8.18 @ 90 in the 1/8 3 weeks ago with a 100 shot. still an otherwise bone stock car on street tires. 2.08 60'. pretty hot day.
jeremy
Car: '82 Z28
Engine: 350HO
Transmission: M4
I can tell you that i can run 1 mile in under 30 minutes, but i'm not about ready to grab the running shoes to prove it to you......
RRRIIIIGGHHHHTTTT, mid 13's with nearly 420 HP to the wheels...
Or are you guessing like your flywheel numbers indicate? I suggest you take a trip to the track and get real numbers before you get your hopes up. Before you say anything, I do have actual numbers and hard data with my LS1. I don't bench race. :lala: Last edited by 25THRSS; May 23, 2004 at 12:30 AM.
Car: 86 IROC Convt
Engine: 305TPI
Originally posted by tilstad
There's a guy in my country...
Where are you located? Im in Porsgrunn.
Not too many of us 'wegians here
Ken
You have 373.5 hp to the wheels WITH NITROUS, which you won't be able to use until well into second gear. You dreaming again
Or are you guessing like your flywheel numbers indicate? I suggest you take a trip to the track and get real numbers before you get your hopes up. Before you say anything, I do have actual numbers and hard data with my LS1. I don't bench race. :lala: jeremy
Originally posted by DIGGLER
im not sure i understand. i can run 11's all day long on street tires with a 150 shot on a otherwise stock ls1.... screw 12's. just have to know how to drive halfway decent.
jeremy
jeremy
