big rims
Old Sep 4, 2005 | 03:44 PM
loud_mouth22's Avatar
Car: trans am 86
Engine: 383
Transmission: 700
big rims
whats the biggest widest rims we can buy for our cars if you have any pics please post them. Also is it simple to do a slight tub job to fit wider tires
Old Sep 6, 2005 | 11:23 AM
ls2twntur1200hp's Avatar
Car: 1988 Firebird Formula
Engine: 5.2 tpi
Transmission: th700r4- TCI
Axle/Gears: fourth gen rear 3.42
Here is a Pic of 20's in stalled on a 91 z28. there were no mods needed to fit the whells and the car is dropped two inch's.
Old Sep 6, 2005 | 11:29 AM
Engine: 5.2 tpi
On the rear there is a maximum tread width of 11 inches. On the front it's 8 in but if you drop the car there will be a rubbing problem when you turn the wheel al the way. If you wanted to go wider then that on the back you could order a wheel with a special backspacing. If you use the 11in rear tire I would recomend using the spacer for the rear disc brake cars.
Old Sep 6, 2005 | 11:36 AM
dennisbernal91z's Avatar
Car: Building LS3, T56 Z28
Engine: LS3
Axle/Gears: Moser/ 4.11
If you don't mind them not "TUCKING" more of a drag kinda look, and a bit of bulge you can run 11" rims in the back.
This is a pic of 335's.........they are just the "while the car is being built".........tires
When she is done, 315's will be on there. Less bulge and maybe I can lower the rear a bit more.
car in pic has no tranny or engine
Old Sep 19, 2005 | 03:31 PM
JDF-Z28's Avatar
Car: 1983 Z28
Engine: GMPP 350, 92 TPI
Axle/Gears: Auburn gear posi, 3.08
Wow, those 20's look like one of my "muscle machines" toy camaros I have sitting on my shelf
Fanatic1074
Oct 3, 2022 05:57 AM
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
Rocket-Doc
Nov 14, 2015 02:08 PM
dbrochard
Exterior Parts for Sale
Oct 10, 2015 01:03 PM
