tire recommendations with budget
Car: 1991 Z28 (sold)
i have a budget of about 50-60 each for rear tires. i need something that has good traction in the rain and decent traction dry. right now i have goodyear eagle GTII's (from the previous owner) and they got me into trouble in the rain (which is why i needed a new panhard bar....) they were discontinued by goodyear, i wonder why
245/50/16 what would u guys recommend?
thanks
thanks
Car: 1987 Monte Carlo SS
Engine: HSR 383 AFR180/268XFI EBL
Transmission: 200-4R, Edge 2800 L/U
Axle/Gears: 7.5/3.73/PowerTrax No-Slip
Locally, I got Kuhmo 711s for under $70 apiece mounted and balanced. They've got great dry grip, and they're directional, so wet traction is good also. The reviews I read said to never drive them in the snow, though; so, if you see plenty of the white stuff where you are, I'd look for something else.
Honestly, I havent driven them enough to tell. Right now, I'm rebuilding the suspension (all of it), and plan to do my TPI swap very soon after. So, maybe by late spring to early summer, I can start putting some miles on them.
Car: 1988 Pontiac Formula 350TPI HARDTOP
Engine: 04- 350 Crate Motor with Crane Cam
Axle/Gears: 10 Bolt Posi 3.73:1
Tires
I Presently am running with Hankook VENTUS H Rated Tires .
245/45/16 . These are BLACK WALL Tires . No raised White Lettering . I do not know what their Price is EACH , but they are Reasonable .
I also have a Question for ANY ONE - What is a Good Performance Tire with WHITE RAISED LETTERING for the 3RD Gen with 16 Inch Wheels?
It seems it is HARD to Get Lettered Tires where I am Located . Every Tire I ask about from Dealers is BLACK WALL ONLY . Geez , I think the LETTERING on Tires is SEXY ! What do I gotta Do , get Mickey Thompson's ? LOL
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
Finding a 16" performance tire for a car,trucks are a different story,with raised white letters is going to be tough.Just about all I've ever seen have raised black letters.You might try a search on a website like Tire Rack( http://www.tirerack.com )to see if any companies make what you're looking for.
Car: 1992 Camaro RS
Engine: 3.1L
Falken Ziex 512 for $65/tire in the size you're looking for. Great rain tire, pretty darn good in the dry too, and overall an awesome bang for the buck tire. You will be very hard pressed to beat this tire for the price. Sears carries them and will usually price match, even on Internet pricing. http://www.edgeracing.com/tires/2455016/ is where I found this price, but keep in mind that is for the tires only, NOT mounting and balancing. Your target price of $50-$60 is a pretty tough order for that size.
Car: 1991 L03 700r4 RS
Engine: 1987 WS6 Trans AM Lb2
Transmission: Th350 red neck Performance 3k stall
Axle/Gears: 95 Mustang 8.8 built with 3.73s
I second the Zeix's, I pulled 2 off of a 3000GT virtually brand new and the wear on them is awesome, plus they're A rated traction and not to awful in the rain.
friend owned Kuhmos, broke belts in all 4 of them on his Eclipse; I'de definetly go with the Falken Zeix's before the Kuhmo's; besides at Sears the Falkens were on sale a while back and were even cheaper than the Kuhmo's, no clue if they're still that way but it would be worth checking in on. PS the g/f runs Zeix's all around on her Nissan Altima, I trust these things in a major way.
Originally posted by CrazyHawaiian
My honest recommendation is not to do tires on a budget. I would spend as much as possible for the best ones possible for your application.
Car: 1991 Trans Am Convertible
Axle/Gears: 3:08
i had the same exact question.but i need all 4 and ended up going with the falken ziex 512 size 255/50/16...they are great in the rain and drive i am very satisfied...they dont rub at all...the best thing is i got them to the door for $308....that is my suggestion from experience...check them out at edge racing...try this edgeracing.com/tires/2555016/ hope this helps man....
Car: 89 Formula
Engine: 383 vortec tpi
Transmission: t56 woot
RAdial t\as come in a 245 50 16 that will fit and fill out the wheel well a little better than stock and its really not a bad performing tire for the $$ I would look into that
Axle/Gears: 3:08
btw...The 255's i suggested were only 1 more dollar a piece than the 245's...thats the reason i went with them
Car: 1992 Camaro RS 25th Aniversarry Edition
Transmission: TH-700-R4
Axle/Gears: 10 bolt with 3.23's and SLP Posi.
no complaints about my Kuhmo 711's. great tire for the price.
sure they dont grab like a drag slick, but then again, they arn't a drag slick either. if your broke and need tires(like i did) this is the way to go.
Lower dollar Kuhmo tires are junk period, you'll never see them on my car because they break belts. Some Mastercraft tires are the same way and you won't see those on anything I'm riding in unless they came on it. The Zeix's are great, g/fs car has around 40,000 miles on them and the wear is excellent, friends automatic Eclipse had the Kuhmo's on it and they lasted about 60,000 miles total. You won't regret ditching those Kuhmo's, they get good reviews because people get them so cheap they think "well it was worth it in the end" or they drive places where they never hit pot holes or debris in the road. Sorry for the rant but those Kuhmo tires just remind me of Kia's, they're known to suck and people see it but they still know this one guy who had them and "never had any problems" so they talk themselves into buying a set to save some change when good tires were only a few dollars more away... shew that was a load off there, it's nice to see guys honing in on the zeix tires, these are seriously nice tires for a good price.
Car: 1992 Camaro RS
Engine: 3.1L
There's another very similar thread going on around here talking about the Falken Ziex 512 vs Kumho Ecsta 711. Yep, the Kumhos are about $8 cheaper per tire, but in my experience with both tires on the same car, the Falkens win hands down. There's almost no comparison, and I initially liked the Kumhos.
No disrespect to 92MaroRS as I have no doubt that your experience with the 711s has been positive, but for the few dollars more it takes to get into the Falkens I think they're a better move.
Well, tirerack didnt list the Falken's when i was in need of tires as well so i wasnt even aware of that option, but alas, im satisfied and will leave them on until they are bald, or i get new rims.
Originally posted by PHAT89TA
i got kuhmos extas for 58 bucks each from tirerack. Sizes are 245/50/16's
hopefully this should work:
tire rack selection
what about either of the Sumitomo tires? they dont seem to be rated much higher than the kumhos.
i found the falken tires for 71 each from discount tire
im changing my budget to 60-80 dollars because im not going to find low profile tires and cheaper
and one more thing, im just getting 2 tires for the rear...is this a bad idea?
tire rack selection
Axle/Gears: 3:08
your budget is perfect for the falkens now.....not really a bad idea if two is all you need....if they are only going to be for the rears go for some bigger ones like the255/50/16's...that is as long as you dont intend to rotate.....
Car: 1987 Pontiac Trans Am
Engine: 305 LB9 Tuned Port Injection
Transmission: 700-R4 Automatic
Axle/Gears: Saginaw 10 bolt 2.73 posi
I would recommend B.F. Goodrich G-Force Sports- excellent traction dry and pretty good in the wet. I paid about $90 a piece out the door after I called a dozen tire shops in town. The price started at like $140 a tire and ended up being just shy of $90 when I finished calling.
Axle/Gears: 3:08
I just got four falkens in that size...and i had the same concern.But to my suprise none of them rub at all on my 92 rs...if i can get my cam to work i will post some pics...but i am really satisfied with them...they dont buldge out over the rim but they do have a rim guard on them to keep the curbs and stuff from scuffing your wheels...the 255/60/15's are about the same size around as the factory suggested 235/55/16's so there is really no differance in the height and they are just a little wider but dont protrude out of the fender...I live in the county where there are alot of hills and bumps and i have noticed no rubbing on my fenders at all....hope this helps....if i had it to do all over again i would have went with a 275/50/16 on the rear to give it that wider in the back look...but thats just me...
does anyone have any pics of 255 tires? how much do they stick out? im worried the falkens will look bad because they already have a rim protection ridge thing. it will only cost 6 more dollars to get 255's...how much more tread am i getting in inches (compared to 245)?
Car: Pair of 92 Z28s
and for a side note...dan ur back! remember me buddy? never knew u stayed on the board with a different name good deal.
Axle/Gears: 3:08
ok im going to get the 255/50/16 falkens. thanks for the info guys.
anyone have any opinions about if i should temporarily use that wheel and tire untill i can find a Z28 wheel?
Car: 1992 Z28 (Heritage Edition)
Axle/Gears: 2.73 Posi
How much better are those Falkens than the stock goodyears? I think to get the tires that came on my car from the factory is like over $100 per tire, but from what i gather there pretty ****ty goodyears. What do you guys think? How much better are these falcons, or even like fuzions or something, than my stock replacement goodyear tires.
Originally posted by dwillis
all i can say is if you do be careful it looks pretty bad....is it a front or a rear wheel
...no hard cornering or burnoutsBTW how do you pronounce "Ziex", the name of the tire
Car: 86 IROC, 89 GTA
Engine: 350 blocks, both of em
Transmission: 700r4s
Axle/Gears: 10 bolt and 9 bolt, 3.73, 3.23
Fuzion ZRis are really good tires... They were rated 5th out of like 40 some tires.... Nice and cheap as well. I bought a set for my IROC
Axle/Gears: 3:08
its a rear...i just want to be able to use the car for my date on tuesday
those would be fine to use as a temp to get by...just didn't want them to be on the front where you would loose your brakes if you had a blowout...p.s. Good luck on your date
...no hard cornering or burnouts Thread Starter
well i went to discount tire today and got a "full size spare" its a 205/xx/15 chrome steel wheel. its ugly but its the same diameter as the stock wheels so it will get me by untill i can find a Z28. its been impossible to find a damn Z28 wheel...
well my 3rd gen is officially trashy but at least it gets me where i need to go
Tires
I was just Wondering Guys , What do you think of the Tires I mentioned I had on my Car ? HANKOOK Ventus HRI 's 245/45/16 ?
They Any Good ? I bought the Car with Them on It . Comments.?
They use those same style 16in rims on newer S10's I was planning on picking up a set from the junkyard as spares.
Axle/Gears: 3:08
well my 3rd gen is officially trashy but at least it gets me where i need to go [/B][/QUOTE] you think yours is trashy!!!
Mine has red duct tape covering the old RS spoiler holes where i put a Z28 decklid and spoiler on mine(just until i get it in the body shop of course......but at least its red tape right...you cant tell until you get up close....heres a far pic of it
