18x11 IROC Wheels....saga continues
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
Re: 18x11 IROC Wheels....saga continues
I've got 255/60/15 rears and 235/60/15 fronts, and the ratio you have reminds me of mine if it were supersized lol.
Car: 88 Iroc vert
Engine: 305 tpi. cts-v brakes
Transmission: Tremec T-56
i ran the adapters on my 17x11 zr1's then just kept them for my 18x10.5 zo6's
btw,you car looks sweet.looks slammed like mine
Car: 92 Z28 Camaro
Engine: Procharged 406.
Axle/Gears: Moser 9" 4.11 Gears
Car: 88 Iroc vert
i rolled the fender lips and did a lil banging with a hammer on the inner fender well but not alot.
Car: Building LS3, T56 Z28
Engine: LS3
Axle/Gears: Moser/ 4.11
Same here and I got my ZR1;s to fit flush with the lip. I still need to roll the lip, but thats it. They "tuck" just the way I like and when people see the 315s on the tire and see that they don't stick out, they really seem to like all the meat under the rear. Grip is excellent off the line too!
Car: 88 Iroc vert
are you lowered at all?im pretty slammed so rilling the fender lips were a must also a adjustable panhard bar to center the rear too.when i first put on my zr1's with the 315's i just sit and look at the back of my car...i love the fat meats back there.now i have zo6's with 295's and to me its a huge difference in meatiness.the 315's look way better.
Engine: LS3
No I am stock ride height. I have adj. everything so it was easy to center. I have yet to roll my lip but am doing so soon. Car hits the lip now and then but no big deal. Once they are rolled it will all be squared away.
Car: 1992 Camaro RS
Engine: 305 (for now)
Transmission: 5-speed
Axle/Gears: stock
I am running a 275 / 40 / 18 on a 10.5 wide rear wheel. no fender mods required. Mine are 26.7 tall your should be around 26.1. yours should be just under 1 inch wider. I think with the right backspacing or spacer you shouldn't have to do that much to make them fit.
Car: 88 Iroc vert
im running 295/35/18's on 18x10.5 and 275/35/18's up front on 18x9.5 in 1 of my earlier post i put up a pic shot from the rear showing the stance.
Car: 88 Iroc vert
damn dennis,i feel i know you know lolol.i looked through evry pic and read everything you put out there.loads of pics are great.too bad i didnt know you earlier n lived near you.i would have helped you out on your car evryday.btw what did you do for the rear brakes?since the rears are way wide like mine the stock emergency brake wont fit.what did you do?and im thinkin to do the same as you for the front brakes.oh and btw i used 2 1/4 front and 1 1/2 rear adapters insted of 2" like most try. ohhhh and sweeet *** ride.
Engine: LS3
I am using my stock rear brakes and the E-brake fits fine. The calipers are mostly inside the rim. But they fit fine. No mods at all. Just bolted on. I have stokc 91 disks on the rear.
Not sure if that helps and thanks for checking out he site and thanks for the compliments too!
Later.
-Dennis
Later.
-Dennis
Car: 88 Iroc vert
on mine,where the cable goes through the bracket is ok but the cable itself is/was rubbing till i disconnected itcuz it was gonna rub bad.do you have pics you can take for me?
Engine: LS3
My cable rubs my DS a little. But thats it. Are you talking about the cable rubbing the rim? I assume so.
I can take all the pics you want. i am getting a new computer this weekend so it might have to wait till then. There might be a pic of 2 on my site that has insight in the mean time.
Car: 1990 IROC-Z (De-Badged-Carbon Hood)
Engine: Superram 383
Transmission: T-56 w/upgraded Viper Internals
Axle/Gears: 3.73 18x8 and 18x11 irocs
Hi Guys,,
Finally, here are the pictures of the modified wheel wells.
The pictures below are of the Driver side wheel well.
As you can see, the areas outlined with red were modified.
The lower portion of the wheel well was actually cut out and re-welded to allow more room for the tire.
As well, the fender lips were rolled out a bit to allow more room.
I have no doubts that I can now easily fit 315's there. The current 295's have alot of room to move in there!
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
so you have not interference with the bump stops huh? If i can find a guy around here to widen my wheels, i will get to see what kind of hacking i get to do. looks good
im liking the 2pc rotors, they look like my trucks brakes, what are they? baer?
Engine: LS3
Looks like what I did. I just need to roll the rear lip. How did you do it? Did you have a body shop do it? I need to do it to mine. My Nitto Drs are rubbing a little when I hit big bumps. Thx
Beast- though the sentiment makes sense, the details you gave are not consistent. First, filler metals in most welding _are_ stronger then the base, like you said, but not usually in aluminum, where the filler and sometimes the HAZ can be as much as half the strength of the base. Usually that is made up for by forming a weld bead that is larger/thicker than the base (which from the pictures here does not appear to be what they did), or by re heat treating the part afterwards (I doubt that’s what they did either, since I can’t imagine how they did it without screwing up the finish or warping the finished wheel. Because of that, in my eyes that wheel would be suspect.
Wrought aluminum? I’m assuming you mean a forging?
WRT to _never_ modifying stock wheels… well,
- WRT to repairs, there are sections of most wheels that are excessively thick and many times as strong as they need to be to start with that can be repaired
- not all factory wheels are cast
- most companies widening rims do not use pieces of cast rim to widen the rim, but they cut it near the “hub,” using it as a cast center piece and the section added on is an aftermarket piece which is significantly stronger than a casting would be.
In other words, it can be done right, safely, but from what I saw in the pics I kind of wonder.
WRT fitting these things in there, I think people are making a bigger deal of it then it is.
I have 295/35-18’s on the back of my project car on some 18x10.5” ZO6 rims, using a 58mm backspacing and 2” spacers, with the stock 1/8” spacers (cast iron drum brakes) installed and uninstalled I was able to drive around with no rubbing with _no_ mods to the wheel wells.
Since it was clear that with the suspension drooped it would hit the bump stops, I eventually want to tuck them in another ¼” and also intend to run much larger/taller drag tires on the car, I did take the plasma cutter to the bump stops/supports and rolled the fender lips (used an eastwood type roller… piece of cake but don’t let anyone tell you you can do it without damaging the paint, half of the paint flaked off the lips when I did it, but I did it now before the car was painted). Since I intend to tuck the big drag tires like the stockers, I know that I will have to hammer the inner fender near the front, inside, but I don’t believe that I’ve ever seen any size tire come close to contacting that lip that runs around the inside in the middle where you guys are doing most of your hammering.
Engine: 5.7
So just to confirm MR IROCZ.....
I think you mentioned using spacers at one point. Are you still using them and how thick?
Did you have to modify the LCA's at all?
If you had to do it again what would you have done differently? Stick with the 18x11 or go 18x10.5 wheel?
Thinking about doing something simliar and yours turned out great.
Car: NissanGTS-T, Nissan350z, 89IROC
Engine: 350ci
Transmission: TH700 4 speed automatic
Axle/Gears: 2.77
WOW, I can't believe I have read the whole thread to realise at the end it's over 4 year old, great read thou..... I too would like to know where you get 18" OEM IROC rims, all I see on the net are the chrome jobs, I'd like the machined look with gold.
(Just logged in to see my avatar .. 86 IROC .. has been swapped with the post above)
Changed Avatar to the new IROC I'm going to pick up.
Car: '87 GTA hardtop, '86 IROC hardtop
Engine: 385 DFI, 350 carb
Transmission: T-56, T-5
Axle/Gears: ls1 torsen 10-bolt, 9-bolt disc
Car: 2012 F350 lariot/1991 Camaro RS
Engine: Powerstroke/6.0
Transmission: 6R100/4L80e
Axle/Gears: 3.73/3.42
Hi Guys,
I am not sure what the backspacing is it at this moment. I want guesstimate atleast 7". The wheel shop just basically added 3" of material to the rear of the rim. Unfortuanetly, the rims will not fit the car now. I need to do some major 'surgery' to the inside fenders!
That last picture is a optical illusion. Those are both the rear wheels, even though one looks smaller.
I am running 18x8 255/45/18 on the fronts, and 295/40/18's on the rear.
Tommy
Tommy
What kind of tires are those
I will be doing the same as you I just picked up a set of 2012 Corvette GS wheels that are 18x9.5 fronts and 19x12 rears
Car: 90 IROC-Z
Engine: LB9
Transmission: M5 5spd
Axle/Gears: 3.42 POSI
I love your wheels! Now if they would only make the 88-90' in a bigger size I would get them.
Engine: 350ci
Axle/Gears: 2.77
Car: 90 IROC-Z
Engine: Lsa
Transmission: M6
Axle/Gears: 9" spooled 3.70
heres a camaro with them https://www.thirdgen.org/forums/memb...en-91-z28.html
Engine: 350ci
Axle/Gears: 2.77
Mr. IROC-Z .... You bought 18x8, where did you get yours from?
I'm waiting on 2 separate quotes for redoing the chrome rims to look OEM gold.
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
Car: 1985 TA
Engine: 350 Carb
Can anyone tell me if any other factory rims would fit a third gen TA? Besides camaro of course. Thanks
Car: 1987 Camaro
Engine: 2.8 V6
What size spacers are you using? I just biught some 18x11s and I'm not sure what size I'll need. Also not sure what size tires I want. They have 315/30r18s now but thats a little big.
Car: 1986 IROC-Z
Axle/Gears: 4:10
No spacers, he did it the right way.
If you read through all of the posts you can get a good gauge on how much work went into making this happen. I'm pretty sure if you stuck spacers on a wheel that wide, it would stick out like a rollerskate in the back.
Car: 1986 Camaro Z28
Transmission: 700-R4
Hey so this is totally off the subject but I had to ask MR IROC-Z... is that the stock lower front spoiler...? I've got an 86 Z28 and my spoiler looks quite different. There's two listed on hawks third gen, one for 85-90 and one for 91-92, both slightly diiferent but yours looks to be different to both of them..? It seems to jut out further, has a sharper look to the apex and looks a little deeper too... I'm looking for something similar and was wondering if you had it custom made...? Adds great attitude to the from on of the car... Also you nailed the stance in every way with those wheels/tyres... looks mean as
Car: 1989 Camaro IROC-Z Convertible
Engine: 5.0
Transmission: 5 Speed
Axle/Gears: 3.08
Hi Tommy, I just ran across this thread and love the wheels. Can you tell me the brand of wheels that you purchased here?
The last post is almost 7 years old, and I'm pretty sure Tommy sold the car a year or so ago. Pretty sure I follow the new owner on IG. There were a few places out there that sell 18x8 Iroc wheels. I know Hawk's Motorsports sells 'em as well as a few others. Just do a search for 18" Iroc wheel.
Engine: 5.0
Axle/Gears: 3.08
I can find all kinds of IROC replica rims, I guess the point of my question was trying to avoid buying a cheap set and getting as good of a wheel as possible. Looks like they all pretty much look the same but with different prices.
I really love the whole stance of this car. I'll try and find it on IG as well - as I'm interested in what he or she used for a lowering kit. Do you have his IG handle by the way?
Thank you.
Pretty sure the new owner goes by Mr IrocZ actually! .....I'll take a look. ....and yeah, these are all made by the same place. Not a great wheel I'm afraid. Pretty heavy too. Still, if you're not tracking the car, it should work for you with no issues.
Engine: 5.0
Axle/Gears: 3.08
Very good. I'm not an IG user, but it's probably time. I'm keeping the car fairly stock for the most part aside from dropping it / exhaust and some wheels. Definitely not tracking it.
Engine: 5.0
Axle/Gears: 3.08
