going from 15" to 16" factory rims...probs?
Old Jun 10, 2007 | 11:52 PM
eddie jr's Avatar
I tried searching but did not turn up much. I was wonderig if there are problems when going from 15" to 16" factory rims on a car that never came with 16's? Will 245/50/16's fit fine in the front and not rub?
I thought i remember hearing at one time something about the stop on the control arm being different so the wheels don't rub....is that true?
And have any of you guys done this on a V6 car.....with the heavier wheels/tires did it noticeably affect performance given the extra rotating mass and weaker engine? (i read that somewhere and was just curious if there is any noticeable impact).
thanks.
Old Jun 11, 2007 | 12:07 AM
daves12secV6's Avatar
Re: going from 15" to 16" factory rims...probs?
i have swaped my 15" rs wheels for 16" iroc wheels when i had 255/45/16's on all 4 corners it would rub before full lock.but now i have 245/45/16's on it i belive(gota dbl check) and they slightly rub at full lock.
Old Jun 11, 2007 | 12:11 AM
Mikz86TA's Avatar
Car: '86 Trans Am and '03 S-10
Engine: 355ci and 4.3l
Transmission: 700R4 and NV3500
Axle/Gears: 7.625/3.42 Auburn and 8.5/3.08 Gov-
No real issues. Yes there was a stopper difference. But I put 245-50-16 (a stock tire size) on a set of GTA mesh 16x8s on my TA which was an orig 15x7 car. There was a slight rub on the inner fender well up front just above the sway bar curve. But only on a hard lock turn and not enough to warrant danger. I have since put on Ronal Firehawk R15 17x9.5s with a 275-40-17 and have no issues with that either.
Old Jun 11, 2007 | 04:15 PM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
I just swapped out the original 15" rims for 16" IROC rims with 245's on all four. NO rub or issue. Fits like a glove.
Old Jun 11, 2007 | 09:05 PM
L69norm's Avatar
Originally Posted by eddie jr
..I was wonderig if there are problems when going from 15" to 16" factory rims on a car that never came with 16's?...
Just make sure you get a matched set of 16" (i.e. 2 rears and 2 fronts). It's stamped on the rim. They use different offsets.
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
Galaxie500XL
Oct 1, 2015 01:05 PM
