15 in rims. widest tires?
Old Aug 1, 2007 | 04:59 PM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
What is the widest tire i can fit without tubbing out the back with the 15 in. rims?
Old Aug 1, 2007 | 05:15 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: 15 in rims. widest tires?
About 275. After that you need to "tweak" the fenderwell.
This is assuming a wide enough wheel. 275 on stock 15x7 wheels is not recommended.
Old Aug 1, 2007 | 05:24 PM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
ya well i was thynkin 255 mb if im lucky 265 but mostly 255
Old Aug 1, 2007 | 07:08 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
When I bought my 84 it had 265s on it, they looked pretty silly. I wouldn't go wider than the stock 235.
Old Aug 1, 2007 | 10:35 PM
Sonix's Avatar
Car: 1982 Trans-Am
Stock 235? What year had stock 235s? I didn't even know 265s existed, who makes a 265?
Old Aug 1, 2007 | 10:46 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
235s were an optional size in all years, AFAIK. The 265s I had were Goodyear Eagles. Dunlop still makes a 265, I don't know if anyone else does.
Old Aug 2, 2007 | 02:02 AM
5678TA's Avatar
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
i think mw66nova had 295/50-15's on a stock rim.. BIG BULGE
Old Aug 2, 2007 | 09:50 AM
Sonix's Avatar
Car: 1982 Trans-Am
He used 275/60/R15's, haha, I saved the pictures on my computer at home.
Old Aug 2, 2007 | 12:49 PM
89formula350b2l's Avatar
Car: 92 Camaro
Engine: Dart SHP 406 HSR, LE heads
Transmission: Performabuilt Level 2, Vig 3200
Axle/Gears: S60 373
do you have pictures of that? may i see
Old Aug 2, 2007 | 01:53 PM
Sonix's Avatar
Car: 1982 Trans-Am
https://www.thirdgen.org/forums/susp...-15-stock.html
Links don't seem to be working right, right now. If clicking on it doesn't work, fix the URL in your browser.
Old Aug 4, 2007 | 09:23 PM
vwdave's Avatar
I have 265/50/15's and they seem to tuck in ok. I do not have very much room on either side, so choose your backspacing very carefully.
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
dbrochard
Exterior Parts for Sale
Oct 10, 2015 01:03 PM
TheCardinal
Oct 1, 2015 07:40 PM
