17x9" too much?
Old Mar 22, 2008 | 01:24 PM
jlc84cam350's Avatar
Car: 84 camaro, 92 yota 4runner
Engine: 305 lg4 out of 81 z28
Transmission: th350
Axle/Gears: Not sure believe its 3.23
17x9" too much?
hey, i am looking for a new set of rims for my camaro, been leaning alot towards the american racing rebel style ----> http://cgi.ebay.ca/American-Racing-R...QQcmdZViewItem
problem is they are 17x9, is that too much for this car, 9" is pretty wide, do you think its gonna rub, note car is being lowered about 1.25" al around. Don't know what size tire i should go with and am expecting the tires would be pretty expensive for a 9" wide rim aye?
Old Mar 22, 2008 | 09:10 PM
pearl_iroc's Avatar
Car: 1988 Iroc-Z 28 Camaro
Engine: LSX
Transmission: MN12
Re: 17x9" too much?
17x9 is a good size you shouldnt have ne rubbing issues
id go with 275 40 17 (on the rear) on that size rim, nice choice of wheel by the way
Old Mar 23, 2008 | 10:22 PM
Lonnie P's Avatar
Car: 91 Formula
Engine: 2012 LS9
Transmission: 4L80E
Axle/Gears: Strange 60 3.54:1
Re: 17x9" too much?
The Rebels will need a front spacer to clear both the tie rod & also the center hub is deeper than the center of the wheel. probably 5/8" to 3/4" thick & the dust cover will need flattened so the decorative center fits.
There are a few variations of that wheel design. I had 2 sets that were different in the center thickness Measure yours before buying spacers.
Old Mar 23, 2008 | 10:34 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
Re: 17x9" too much?
Those are a good size. I have 17x9s on mine with 275/40ZR17s all around. No issues to speak of. Make sure you research and get the correct spacers though.
