all about performance rims... (dimensions)
Old Aug 22, 2008 | 11:51 PM
engongam's Avatar
Car: 1991 Trans Am GTA
Engine: 502 Ram Jet
Transmission: TKO600-racing gears
Axle/Gears: 12 Bolt Moser-33"axles-3.91 ratio
Hello,
I really need some help here, I am doing a 502 swap, transmission swap (auto to manual) AND ETC... I bought a new 12 bolt moser rear end with stock dimensions of 91 transam GTA. I will buy an enkei lightweight rim but I have no idea about offsets, backspacings, etc. I am thinking of buying these: http://enkei.com/RacingSeriesSpecs/RPM2.html
Can you just tell me the right dimensions? I came to US just to buy parts to my car and I am running out of time. Thank you for your help...
I have 12.2" wilwood disc brakes at front and rear...,
I will use nitto nt1 slicks on these rims and I want to keep the rear tire width size as big as possible. On tracks I will use enkei's, on street I will use orginal gta rims and diffrent type of tires. I just wanted to let you guys know
Old Aug 23, 2008 | 12:33 AM
igotta355z28's Avatar
Car: 1991 Z28 1LE
Engine: 370CID GenIII
Transmission: 4l60e
Axle/Gears: 4.33 Moser 9inch
Re: all about performance rims... (dimensions)
http://www.camarotech.com/WheelsAndTires.html
that chart should be helpful and also what are u planning on doing with the car cause Nitto NT01 are not drag radials they are for like autox and such they have a stiff sidewall for cornering and are not the best for say street strip drag racing. for that if u wanted to stick with Nittos ud want the NT555R tires...
Old Aug 23, 2008 | 12:47 AM
engongam's Avatar
Engine: 502 Ram Jet
thank you for the great information, I wont use the car as a drag race car, I will use it on circuits. Time trials mostly... I will corner the car shortly
Would you be suggesting any other tires than nitto if we consider that I will be participating in time trials...??
"The stock third generation '82-'92 Camaro wheel wells will fit 17"x9.5" rims with a 10mm offset (positive) with P275-40ZR17 in all four corners. "
this means that if I buy a 17"x9" rims with 75 bore diameter, these rims will fit and I will be able to use 265-45-17 or similar values tires can be installed on those rims correct??
What about the bolt patern of standart 91 transam rear end I mean the one that I bought from moser... with 33" axles,
Will the calipers and rims be in good positions (I am talking about ET's)
I will be glad if somebody answers my questions, I am really looking for a solution.
Thank you all; especially gotta355z28
Old Aug 23, 2008 | 10:02 AM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
Just an FYI, while those first Enkei wheels you posted look good they won't fit a thirdgen. They're set up for a much smaller bolt circle; like a subaru legacy or honda 5 lug setup. A buddy of mine had those on his legacy and they did look very nice. The bolt circle you're going to be looking for is 5x120.6 I thihk. BMW wheels have been known to use a 5x120 and there are a few guys on here using them. You'll probably find nicer looking wheels if you include BMW wheels. (aside from fully custom wheels)
Old Aug 23, 2008 | 10:13 AM
Saigon_Bob's Avatar
Car: 1991 Camaro RS
Engine: 357cid
Transmission: T5 Swap
Axle/Gears: 10bolt 7.5" 3.23 soon to be 3.73
BMW and mercedes... off the top of my head fit.
Old Aug 23, 2008 | 09:04 PM
engongam's Avatar
Engine: 502 Ram Jet
There are some enkeis that has the bolt pattern of 5x120... here are the specs:
Offset: 38mm
Backspacing: 5.94" Bolt Pattern: 5-120
Rec. Tire Size: 215/45-17
Weight: 17.9lb
Is there any body that exactly know what is the 91 firebird's bolt pattern?
Old Aug 24, 2008 | 10:45 AM
engongam's Avatar
Engine: 502 Ram Jet
http://www.tirerack.com/wheels/Wheel...All&sort=Brand
I just found these rims, these have different backspacing than enkeis
I am looking to the instruction sheet of rear 12.2" wilwood brake kit and it says it has an offset of 2.50 for the rotors...
Can just somebody help me I need to but the rims in a few days...
Thank you for your future help...
I just founf a site that might be helpful for bolt patterns
I found my bolt pattern but still I do not know if those rims are going to fit or not... http://www.myboltpattern.com/Pontiac-Bolt-Patterns.htm
transam: TRANS AM84-9216x85x120.712x1.570.3
and some useful information(I do not know if it is true...)
FIREBIRD 82-9214x75x120.712x1.570.3 FIREBIRD93-16x7.55x120.712x1.570.3 FIREBIRD, TRANS AM67-9214, 155x120.77/16-RH70.3
Linson
Oct 24, 2025 02:00 PM
Pac J
May 17, 2020 10:44 AM
jrdturbo
Mar 31, 2016 02:58 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
SRKLEGIN
Interior Parts Wanted
Oct 12, 2015 07:28 AM
