How wide are these stock wheels?
Old Sep 23, 2009 | 06:46 PM
evilWS6's Avatar
Hey guys,
I don't know what these wheels are called, but I'm pretty sure they're factory. If someone knows how wide they are that'd be sweet.
Here they are
Those are stock right? I don't have the car yet so I'm trying to see as much as I can. I'm asking just because i'm trying to find out what wheels/tires I would go with.
Old Sep 23, 2009 | 07:45 PM
scottwrightF1's Avatar
Car: 1988 Camaro Iroc / 1989 Firebird TA
Engine: Camaro 350 cid / Firebird 305 cid
Transmission: Soon T56 D&D Viper (WC T5) / WC T5
Axle/Gears: 9 bolts; 3.45>3.89 / 10 bolts; 3.08
Re: How wide are these stock wheels?
Need more information. What year is the car? I am assuming is a 6 cylinders?
From the picture it looks like Firebird Trans Am rims, not GTA. I wouldnt think it a Trans Am rims, cause the tires looks too narrow. Maybe, 235's wide tires? Can't really tell if it stock without knowing the year?
Old Sep 23, 2009 | 07:47 PM
1988-305-tbi's Avatar
bad picture.... they don't look stock, probably have a marking inside stating the dimensions, my guess would say 15X8"
Old Sep 23, 2009 | 09:17 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
they look like cutlass wheels or something to me. look like the ones I have a set of slicks mounted on. Mine are actually 14x7, IIRC...haven't messed with them in a while.
Old Sep 23, 2009 | 09:37 PM
evilWS6's Avatar
It's the only pic that showed any of the wheel.
Off topic.. If I'm throwing 15" drag wheels on a mostly street driven 3rd gen, what size should I go up front? 4", 7", 8"? I think 4 might be too thin for street/highway driving?
And then what, 10" out back?
Old Sep 23, 2009 | 09:59 PM
1fastam's Avatar
Car: 1991 transam
Engine: 305 30 over long tubes into 3" y
Axle/Gears: 4:10
see cardomain for rims,jimmy
Old Sep 25, 2009 | 02:29 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
if they're 15" steel with stainless trim rings and plastic centre caps (I can't tell for sure, but that's what they look like) then they're 15 x 7" (inside the bead) and if they're 83-85 Monte SS, those are zero offset (3.5 actual backspacing; 3.75 to 4" B.S. backspacing) S-10 had some that fit that description that would also be 7" and probably zero offset.
LT1Formula
Nov 16, 2015 01:13 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
kah992
Aug 19, 2015 02:55 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
mustangman65_79
Aug 9, 2015 03:00 AM
