show me your aftermarket rims
Car: 87 GTA
Re: show me your aftermarket rieelms
And if you are going to restore a 82, you can't put 16" or 17" wheels on. Because the factory did not offer those sizes on a 3rd gen in 82.
ok - maybe restoring was not the correct wordage, i would like to use 16 or 17 on the car, i checked and they look like they should fit? i have the 14 originals but want to get a little bit larger wheel. what do you think, thanks.
Re: show me your aftermarket rims
Car: 1990 IROC vert
Transmission: 700-R4
Also, you should ask your questions on fitment and opinions in an appropriate thread using the search feature or you can start a new one. This thread is to display/view aftermarket rims as noted in the title, its considered rude to pop in and ask multiple off topic questions as we are trying to look at rims and rides here. Im not trying to flame you, just some simple guidance.
Car: 86 IROC-Z28
Engine: LB9
The wheels are Centerline Daggers 17x8 in the front with 245/45/17 BF Goodrich Traction TA KDW tires and 17x9.5 in the rear with 285/40/17 BF Goodrich Traction TA KDW tires
Car: 99 3000gt 88 gta vert 88 gta h/t
Engine: v6 /5.0 /5.7
Transmission: at/5 speed/at
Axle/Gears: ? /3.45/3.23
Nice car, my brother gave one to the knox. co sherriffs for being a dumbass drunk. Was 5.0 tpi, 5 speed maunal every thing ,87 model with a/c delete.man makes 3 cars he lost like that.
Car: 88 T/A. TOTALLED!! (not by me)
Engine: TPI 5.0
Transmission: 700r4 Auto
Axle/Gears: 2.73 posi
Those are nice!
I May buy some for my T/A. What is the backspacing on those? Are they all 4.5" BS? Also, are the lug nuts way up inside of the (lug) holes? Almost looks like there aren't any there in the pics?.?.
Thanks,
John C.
Thanks,
John C.
Car: '91 camaro z28,imsa widebody
Engine: 383 ci l98,lt1 induction
Transmission: race built 700r4 , ratchet shifter
Axle/Gears: 342;1 detroit true trac diff
i ran bmw m6 rims with 265/30/19 and 295/30/19...nice lookin on camaros
Car: 1988 Pontiac Firebird
Engine: 305 LT1 intake&heads
Transmission: TH700r4
Axle/Gears: 3.73 10bolt GM
Bimmer aftermarket wheels on my Camo:
best regards
best regards
Car: 91 RS
Engine: 350 TBI
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
in the same boat as 91 1le, slightly different style wheel
no spacers (for me anyway), they clear the brakes (thank god) and are meaty
Car: '91 1LE
Engine: 377 w/Stealthram
Axle/Gears: 3.42 Torsen
They are Miro 111's. Fronts are 18x8.5 ET 20, rears are 18x9.5 ET 20. These are a 5 Series BMW fitment. The 5x120 bolt pattern will be corrected shortly.
Car: '87 GTA hardtop, '86 IROC hardtop
Engine: 385 DFI, 350 carb
Transmission: T-56, T-5
Axle/Gears: ls1 torsen 10-bolt, 9-bolt disc
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
See my signature.
TSW 18x8 front 18x9.5 rear.
No spacers. Direct fit with a custom touch
Car: 91 RS
Engine: 350 TBI
I need something wider for the power I'll be putting down. Also curious as to what method you're going to use to "correct" the bolt pattern. I've seen everything from "hub centric rings," different bolts, to guys drilling the wheels.
Car: '91 1LE
And they fit fine with no steering issues? What gen 5 Series wheels works on our cars?
I'm not sure on the years of Bimmers that will work. Just look for the correct offset you need. I'm going to run a 295/35/18 on the rear. Not sure how much bigger you are wanting to go but I don't feel like doing any wheel well modifications so I got what I got. I spent many hours searching for wheels and plugging their specs into the calculators in the stickies above to make sure I got the perfect fitment. I also had my ginormous brakes to clear so my selection was limited. I would have liked to get a wheel with a nice lip but that doesn't jive with big calipers.
Car: '92 Camaro RS | '11 E92 335i
Engine: 305 TBI V8
Axle/Gears: Stock
Just got them a couple days ago, ordered tires, should be in tomorrow
18x8 in back 0 offset
17x8 in front 0 offset
should look pretty decent when all is done
Car: 1992 Camaro RS
Engine: L03 5.0L
Transmission: 700R4 Auto
Makes me sad when you see a beautiful 3rd gen that, if treated right, could be one showy car, and people like you brother treat them like scrap (hehe) and just basically throw them away.
I saw a early 90's Camaro in a Walmart parking lot about 3 weeks ago. The car had at least 3 different colors worth of body parts, looked beaten to and from hell and back, and the shocks were out on the right side making the car sag and even LOOK sad. It looked at me like it was saying "Take me home and take care of me."
Seeing that poor thing was quite the bum-out. Never saw the driver though, but that was probably because it was an abandoned car.
Car: '91 1LE
They actually clear quite well. I call Miro and spoke to a tech that said he was 95% sure they wouldn't work. So I sent him the template from Baer and they checked it.
don't forget to post pics when it's all done, would like to see a pic of them with tires on the car
Car: 92 Firebird, 91 Trans Am
Engine: L31 with HSR, LB9
Transmission: 700R4, 700R4
Axle/Gears: '99 10 bolt 3.90, '01 10 bolt 3.42
Z06 Deepdish.
Made the car look completely different.
Car: 85z28(sold),91 rs, 15'Mazda3GT
Engine: 5.7L V8 350 (ZZ4)
Transmission: 700r4 rebuilt with kits+ vette serv
How much did it cost you for parts on baer brakes and the rims+tires? I'm still looking at zo6 rims but not sure if baer brakes have enough space? They look so sick, I been eyeing those brakes lately, but theres so many different ones. And how hard is it to swap all four originals with drums to baer brakes? Just got a new job last month at Wal mart DC, pays good while I'm also still at school. So I'm stacking it up until summer comes around to get my car running again.
Car: 1991 Camaro RS
Engine: 5.0 V8 305
Transmission: Stock Automatic
Axle/Gears: Stock...For Now
Stock RS rims painted black. I pretty much got a brand new set of rims for 8 bucks. If you take your time and prep they can turn out pretty nice. Obviously nothing like spending thousands on rims but, on a 20 footer in general they look good. The second picture is what they were before paint when I just bought the car.
Car: 1991 Firebird
Engine: 3.1L V6
Car: 1987 IROC-Z
Engine: 383 stroker, 1st F.I. TPI
Transmission: 700R-4. Modified to handle engine
Axle/Gears: 10 bolt 3.42 posi
If you like your rims, don't worry about other's opinions. We get that guff about "old, stock and dirty" from yuppy's riding $40,000 trailered in bikes.
Car: 1987 IROC-Z
would be even better with wooden spokes
and you know this how? LOL
Car: 1989 Camaro RS--
Engine: MPFI
Car: 86 Trans Am
Car: 1991 Firebird
Engine: 3.1L V6
Engine: MPFI
yes I love the rims! And by the way I am not a man. You guys don't like the rims? I think they would look really hot on a third Gen
Car: 1991 Firebird
Engine: 3.1L V6
Car: 1987 IROC-Z
I wouldn't run them on mine, but They might look good on a pink Peterbuilt!!!!
Car: 88 RS Camaro,70 chevelle,92 Geo
Engine: 305 TBI
Transmission: 5 Speed Manual
anyone ever see speed racer
im looking for flat black rims with wholes arounf the rim.... cant find them
Engine: 355 Super Charged
Transmission: B&M Streetfighter
Axle/Gears: 4th gen 342
