Poor tracking in truck ruts
Old Dec 8, 2009 | 01:37 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I currently have factory Berlinetta rims on the car, which limits me to 14" tires. Due to various circumstances, I've been doing two tires at a time, starting with a pair of Cooper 235-60x14's. The next pair was a Discount Tire no-name brand same size. Up to this point, no problem. The Coopers, which were on the back, wore out this summer, so I picked up a pair of BFG TA's, same size.
Suddenly the car started having a lot of trouble with jerking side to side in truck-rutted roads. I discovered they only put 28 psi in them when they mounted them, so I upped that to 32 psi. That helped, but it was still pretty bad, so I went to 35 psi. It's almost tolerable, but still not good.
I had the same issue when I mounted 245-50x16 GSC's all around.
Can't blame alignment, since the tires went on the back. Can't air them up any higher, 35 psi is the max.
Any ideas?
Bubbajones_ya
Oct 25, 2015 08:01 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
loud91rs
Oct 5, 2015 10:05 PM
jaridjohn
Oct 5, 2015 07:01 AM
Numbah-1
Oct 2, 2015 08:27 AM
