UK TIRE SIZE HELP
Old Feb 12, 2010 | 04:58 AM
mickp's Avatar
UK TIRE SIZE HELP
HI I LIVE IN THE UK.I OWN A 3RD GEN WITH STOCK 15" RIMS THE TIRES CURRENTLY ARE 215/65/15. I WOULD LIKE WIDER ON THE REAR WHAT PROFILE SHOULD BE ON THESE STOCK RIMS IS 65 RIGHT? HOW WIDE CAN I GO WITHOUT FOWLING ISSUES. NOT MANY TIRES IN UK 65 PROFILE USUALLY 60 PROFILE ON 15" TIRES.ANY HELP WOULD BE APPRECIATED. THANKS MICK.
Old Feb 12, 2010 | 07:03 AM
Twin_Turbo's Avatar
Re: UK TIRE SIZE HELP
With wider tires the aspect ratio goes down so you retain similar diameter. 60 and 65 are seriously tall sidewalls. Better start looking at 245/50s or thereabouts
Old Feb 12, 2010 | 10:02 AM
mickp's Avatar
THANKS FOR YOUR REPLY BUT CAN NOT GET 245/50/15 IN UK. 245/50 START FOR 16" RIMS.MICK.
Old Feb 12, 2010 | 08:59 PM
Twin_Turbo's Avatar
What can you get?
Old Feb 13, 2010 | 12:05 AM
fast82z's Avatar
Car: 82 Z28
Engine: TT LS
Transmission: 4L80E
Axle/Gears: S60 3.54's
A set of 275/50/15's are a little shorter than stock height, and 275/60/15's are about 2" taller than stock. Both tires are something like 2.25" wider than stock and will fit just fine.
Old Feb 13, 2010 | 04:27 AM
mickp's Avatar
Hi,i can get 265/50/15 size no problem they are cobra gt tyres should be ok? Thanks Mick. Coming over to New York in May do you think tires count as hand luggage haha.
Hotrodboba400
Dec 10, 2019 07:07 PM
TheTraut88
Sep 7, 2015 05:22 PM
SG91camaro
Sep 5, 2015 10:27 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
