2010 Camaro Wheels/Tires on a 3rd Gen?
Old Apr 2, 2010 | 07:18 AM
White92RSVert's Avatar
Thought I would post this here about using 2010 stock Camaro wheels and tires on a 3rd Gen. There are some good deals on 2010 18" wheels and tires as a lot of folks are upgrading to the 19's or 20's and these wheels and tires have low miles and are a bargain... $600 for new wheels and tires!! Here's what I've concluded. If anyone thinks this analysis is in error, please chime in...
2010 Camaro Except SS
Bolt Pattern: 5x120 (4.72")
Center Bore: 67mm
Hardware: 14x1.50 Lug
Offset:
Front: 34mm
Rear: 38mm
3rd Gen center bore is 2.788" (70.8mm) and a 4.75" pattern.
It could be done if you ground down the center bore 3.8mm but that's a bit much and I would question the wheels integrity at that point. You would also need to space quite a bit in order to get inner wheel well clearance. You could also not use the stock tire size. It's too tall. You would need to have a 40 or less in order to use 18" wheels for fender clearance. Not sure if this helps anyone but me but it's informational for everyone nonetheless.
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
redmaroz
Aug 16, 2015 11:40 PM
Eagle223usa
Brakes
Aug 14, 2015 09:24 AM
reiderz iroc
Aug 13, 2015 04:57 PM
bjpotter
Aug 12, 2015 06:06 PM
