z06 wheels and spacers..
Old Apr 7, 2010 | 11:47 AM
toolegit86's Avatar
Car: 83 camaro l69
Engine: turbo lsx
Transmission: th350
Axle/Gears: disk rear, 10bolt.
So i just got a set of 18" black with a crome lip z06 wheels. the back spacing seem to be 7.5" off the the mounting flange my question is what size spacers do i need?
Old Apr 8, 2010 | 08:04 AM
kenlamb3's Avatar
Car: 91 Z28 Convertible Camaro
Axle/Gears: Borg-warner 3:27 gears
Re: z06 wheels and spacers..
if your rims are 18x9.5 then you should be fine with 2" spacers cause thatw what im running with my Zo6 rims aswell with many others on here.
Hope this helps
Old Apr 8, 2010 | 11:27 AM
toolegit86's Avatar
Car: 83 camaro l69
Engine: turbo lsx
Transmission: th350
thanks i just wanted to make sure.
Old Apr 8, 2010 | 06:36 PM
Blind Driver's Avatar
Car: 1986 Trans Am
Engine: 5.0
Axle/Gears: beats me
Hope this helps
All depends on the offset
Old Apr 27, 2010 | 04:56 PM
89iroc-z559's Avatar
Car: 1989 camaro Iroc-z
Engine: 5.7 Tpi
Transmission: 700-R4
Axle/Gears: dont know what this
Hope this helps
what if i got 18x8.5 in front and 18x9.5 in the rear what spacers would i need?
Old Apr 27, 2010 | 09:00 PM
kenlamb3's Avatar
well to be honest im not sure about the 18x8.5,but i would still assume the 2 inch spacers.
What i did was find people with the same year as mine that were running the same size rims i was gonna be running and asked them,plus i read alot of diffrent post on here from others and the majority of people are running 2 inch spacers with the 18x9.5.
If this doesnt help just look around in other threads like i did an hopefully you will find your answer.
Old Apr 27, 2010 | 11:30 PM
toolegit86's Avatar
Car: 83 camaro l69
Engine: turbo lsx
Transmission: th350
i have 18/10 all the way around. 2.25 front and 2.5 rear fits and looks good.
obeymybird
Exterior Parts for Sale
Nov 3, 2015 08:10 AM
xXIROC ZXx
Wheels and Tires
Sep 15, 2015 11:18 PM
Saxondale
Sep 15, 2015 06:42 PM
punkmaster98
Sep 8, 2015 09:45 PM
turbobuick88
Wheels and Tires
Sep 8, 2015 08:27 PM
