Bead Blasting?
Old Apr 12, 2010 | 08:14 PM
MrPhotographer0's Avatar
Car: 1984 Camaro Sports Coupe
Engine: 355 chev
Transmission: none at the time
Axle/Gears: stock 10bolt v6 gears
Bead Blasting?
I want to re-finish my camaro rims and i'd really rather find another way to do it than the hand sanding, but if it comes to it, i will.
https://www.thirdgen.org/forums/whee...g-project.html
that project is something i'm looking for as an end result. If i stuck my rims in the blast cabinet, would it help any, hurt them or just be a waste of time?
Old Apr 19, 2010 | 11:26 PM
mechanic1992's Avatar
Car: 1987 IROC-Z
Re: Bead Blasting?
It depends on the pressure and what type of beads you are shooting at the rims, but if you use glass beads at a low PSI i think you should be fine, just lightly go over the rim and dont stay on one spot for too long or youll start taking away a little metal. But ive beadblasted plenty, are your rims aluminum or steel?
Old Apr 20, 2010 | 05:51 AM
Engine: 355 chev
Re: Bead Blasting?
not sure. i think they're aluminum
RyanJB
Members Firebirds
39
Nov 20, 2018 03:30 PM
sailtexas186548
Feb 17, 2017 03:07 PM
86White_T/A305
Mar 6, 2016 01:48 PM
Whata69
Mar 2, 2016 06:34 AM
SG91camaro
Sep 5, 2015 10:27 PM
