will 15x11.5 fix our third gen ?
Car: Red 1988 Iroc-Z hard top
Engine: 305 ( LSX swap soon )
Transmission: 700r4 ( T-56 swap soon )
Axle/Gears: What ever gear that come in 88 iroc
What I need to do to make 15x11.5 wheel to fix my third gen ? and what is best tire side for this wheel ?
http://hattiesburg.craigslist.org/pts/1690370289.html
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: will 15x11.5 fix our third gen ?
those wheels wont fit your car, they are 5 on 5 pattern, wont bolt up, and they dont have nearly enough backspacing, they will sit outside the wheel well a good bit.
to properly fit the wheel on you car you need 5 x 4.75 bolt spacing, and at 11.5" wide, 8" of backspacing. Which requires a lot of wheel well modification, like a minitub.
however, im not aware that the wheel in question even exists in a 11.5" width? they may be measuring ther wheel wrong and its really only a 10.5" wheel. Bit it still wont fit.
you cant use them, move on
