my trans am wheels
Old May 26, 2010 | 09:23 AM
kjgroen's Avatar
Car: Trans Am
Engine: L69
my trans am wheels
They are 245 45 17 x 8 fronts and 275 40 17 x9 rears made by custom wheels market..
Old May 26, 2010 | 02:22 PM
82T/A's Avatar
Car: 00Blazer,82T/A,70 Nova
Engine: LG4305
Transmission: Built 700R4
Axle/Gears: 10 bolt, 4.11 posi
Re: my trans am wheels
very nice!
Old May 26, 2010 | 02:57 PM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
Now you just need to lower the car and get rid of the 4x4 stance
Old May 26, 2010 | 03:06 PM
itsMikey's Avatar
Car: 89 GTA/93 S13/91 Si
Engine: 5.7 350 TPI
as do i
looks great tho!
Old May 26, 2010 | 04:08 PM
kjgroen's Avatar
Car: Trans Am
Engine: L69
yep, deciding what springs to go with.............
Old May 26, 2010 | 08:08 PM
jerodo8008's Avatar
Car: 1985 Trans Am 1988 Chevy c1500
Engine: 5.7 v8 /4.3 v6
Axle/Gears: 3.08 & ?
how does changing tires like that effect your spedometer, and how do you fix it so that it still reads properly? I had that problem in my Pickup when I bought it, the PO had too SMALL of tires on it....
Old May 26, 2010 | 08:14 PM
Stephen's Avatar
Car: 87 GTA
A speedometer doesn't care what size the wheels are. The only thing that matters to the speedometer, is the overall diameter of the tire.
I went from 245/50R16 to 285/40R17 to 315/35R17 & my speedometer has read just fine with each tire change.
kjgroen's Avatar
Car: Trans Am
Engine: L69
on mine the tire size was almost identical to the original size, otherwise change the speedo gear/ gears
Old May 26, 2010 | 08:17 PM
jerodo8008's Avatar
mkay, I understand now, I thought that the biggest number in the tire measurement, ie. 245, 275, 315, meant the diameter.
Old May 26, 2010 | 08:50 PM
itsMikey's Avatar
Engine: 5.7 350 TPI
width...and you should check out some eibach sportlines
Mikey
Old May 26, 2010 | 09:03 PM
Stephen's Avatar
Car: 87 GTA
245/285/315 is the width. 50/40/35 is the % of the sidewall height.
50% of 245
40% of 287
35% of 315....All the same overall diameter.
As the width gets wider, the sidewall height drops, to maintain the overall diameter.
Jorlain
Aug 24, 2022 05:11 PM
BlueIroc-Z
Jun 9, 2019 03:22 AM
colton_carlson
Mar 8, 2019 12:21 PM
milk
Aug 10, 2015 06:26 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
