Repainting GTA wheels?
Subscribe
Jul 21, 2010 | 02:29 AM
I'm thinking about how to go amongst doing this, my black GTA wheels well aren't.. black anymore. Their kind've an awful grey.
Me and my grandpa were going to attempt redoing two at a time, what do u guys reccomend? We were going to take a pressure washer to them to try and remove as much gunk as possible, but im not seeing how else to prep them rather than taking a wire brush to them.
ADVICE PLEASE? I know I sound dumb, but really, It doesn't even seem like most of the original black paint is still on these wheels. We literally plan on priming and spraying them with high quality spray can. Anything will make them look better. Advice advice?
Reply 0
Jul 21, 2010 | 01:32 PM
Re: Repainting GTA wheels?
Any advice? :/
Reply 0
Jul 21, 2010 | 03:20 PM
well what I would do if I was you would be to strip the clear coat off the wheels, have the centers powdercoated black, and then polish the dish up. When you put them back on the car, the wider looking rims go on the front, and the skinny looking ones in the back. I remember your car had them switched, and I just don't like the skinny rims up front it looks funky.
Reply 0
Jul 22, 2010 | 03:48 AM
Quote: The wider looking rims go on the front, and the skinny looking ones in the back.
OMG REALLY, I did not know that mine were backwards! What is the reason for the difference?
Reply 0
Jul 22, 2010 | 03:53 AM
How would I strip the paint off of the centers? and how much would it cost me to get them powdercoated, and where?
Reply 0
Jul 22, 2010 | 08:15 AM
I have done this a few times. Once to paint the spokes silver then recently to paint them back to a factory black.
Take off the wheel/tire (i know, duh!).
Set it somewhere where you don't care about the grass/plants in the area.
Get aircraft stripper from autozone or wal mart. The brush on kind works better than the spray on.
Let is sit for about 10 minutes then blast it off with the pressure washer. Be careful to not let it splash back onto you. It burns.
Let the wheel sit out in the sun to dry or use compressed air to speed up the process.
Use a good spray paint. I have used caliper paints and they have worked well.
You can tape off the outer ring to keep it clean or use some mineral spirits to get any spray over off.
It will take a few spray coats mainly because when you think you have hit all of those little openings you suddenly find two that haven't been hit. Take your time between the coats because a run will happen and mess up the job.
Overall not too bad and I usually incorporate some other job to do (brake pads, brake lines, etc) to do along with this job so you are not just standing there between steps.
Good luck.
Reply 0
Jul 26, 2010 | 10:21 PM
find someone that does soda blasting. will take it right off without the mess. works on most all materials... metal..wood...plastic...glass even in some cases. wont hurt substrate like most blasting techniques (ei sandblasting). then all you have to do is clean and paint
Reply 0
Jul 26, 2010 | 10:45 PM
Quote: How would I strip the paint off of the centers? and how much would it cost me to get them powdercoated, and where?
I had my Snypers done at http://www.wheelsamerica.com/index.php?page=main. $100 each, for stripping, powdercoating & polishing the lip. I found a local guy that does the same thing for $85(iirc).
Quote: OMG REALLY, I did not know that mine were backwards! What is the reason for the difference?
If you look at the back of your crosslace wheels, you'll read FRONT or REAR cast into them. Front wheels fit the rear axle, but rear wheels won't fit the front suspension. They are all the same width, 8", but the backspacing is different. The result is a narrower rear track width, which help in stability & bringing the rear of a car back in line, if it gets loose in a turn. A very common thing is to get you 4 front wheels, to run on all 4 corners. Makes the rear look wider, nice stance & any wheel/tire you have can fit any corner. And so that you can carry 1 full-sized spare that way (another front wheel & tire) to fit on any corner.
Reply 0
Subscribe
