Rear Hub
Old Aug 8, 2010 | 01:15 AM
monster283's Avatar
Car: 1987 pontiac trans am gta
Engine: 5.7 V8 fuel injected
Rear Hub
i was raceing my 1987 gta, and hit a wall hard, it bent my rear hub and i cant find any were to get a new one, anyone got some were to look to help me out?
Old Aug 8, 2010 | 01:25 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Rear Hub
Rear hub?
Old Aug 8, 2010 | 02:18 AM
monster283's Avatar
Re: Rear Hub
im think thats what its called, i have rear disc brakes and its the part the wheel bolts onto
Old Aug 8, 2010 | 02:22 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: Rear Hub
That's part of the axle. You're probably going to find that you've done more damage than you thought.
Old Aug 8, 2010 | 02:25 AM
monster283's Avatar
Re: Rear Hub
Damn i took the wheel and brakes off and from what it looks it just the one part that is bent, with out the brake on it turns fine no rubbing or anything
Old Aug 8, 2010 | 02:49 AM
monster283's Avatar
Re: Rear Hub
Old Aug 8, 2010 | 09:47 AM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Rear Hub
Originally Posted by monster283
nothing in that pic is 3rd gen related.
if the rotor turn properly with the wheel and brake off, you bent to caliper bracket or backing plate, and possible the wheel. The axle may be bent too. what rear brakes setup do you have? year?
Old Aug 8, 2010 | 11:26 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: Rear Hub
Don't forget the LCAs, panhard and axle housing, too.
Old Aug 8, 2010 | 07:50 PM
monster283's Avatar
Re: Rear Hub
i have an 87 gta, and there rear disc brkaes, i took the rotor off and it spins freely but the part the wheel bolts to is bent i can see it when it spins, but when i spin it it dosent bind up
hectre13
Dec 11, 2023 08:14 AM
1992 Trans Am
May 10, 2023 07:19 PM
midge54
Dec 27, 2019 04:14 PM
dyeager535
Aug 28, 2015 08:10 AM
Bstrang6
Brakes
Aug 24, 2015 06:45 AM
