Help! Need Tire/Rim Advice!
Old Aug 20, 2010 | 01:45 AM
Pateman91's Avatar
Car: 1991 Camaro RS/IROC clone
Engine: Was 305 5.0, now Carb'd 350 w/ cam
Axle/Gears: Stock
I have looked around and found these wheels: http://www.oewheelsllc.com/Wheels-fo...-p6901928.html . Which are 17x9.5 w/54mm offset in the front & 18x10.5 w/58mm in the rear. Since this is a staggered set up I've decided (after long internet searches and price discrepancies) that I would like to run these in the front: 245/45-17 Hankook Ventus V12's, & in the rear: 275/40-18 Hankook Ventus V12's as well. My understanding about the rims are that you need 2in spacers all around which I have also found. But my real question is if I will run into ANY problems doing this, such as fender rubbing & so forth. Advice on the set up would be great, because with the money I would be paying for this I wouldn't want to buy wheels & tires that I couldn't run, thanks. - Chris
P.S. I think this combo would look amazing on my 1991 Camaro . (I love using these smileys!)
Old Aug 20, 2010 | 11:36 AM
vinny83's Avatar
Car: '83 Camaro Berlinetta
Engine: 305 with aluminum heads, voodoo cam
Transmission: 700r4 auto
Axle/Gears: 10 bolt w/ 3.73 gears
Re: Help! Need Tire/Rim Advice!
wow, only $495? id say thats a pretty good deal. what tires you gonna run on them? those rims look excellent on our camaro's not so much the firebirds..ecspecially if u have a black or red car.
Old Aug 20, 2010 | 11:37 AM
vinny83's Avatar
never mind lol. i saw the hankook's. pretty good setup id say =]
Old Aug 20, 2010 | 11:41 AM
Stephen's Avatar
Car: 87 GTA
I'd go 275s on your 9.5" front. Stock 4th gens had 275s on 9" wheels & what I run on my GTA. 245 are a tad narrow for a 9.5" wheel.
And you can go wider on the rear as well, if you want.
Old Aug 20, 2010 | 03:58 PM
godreject's Avatar
Car: 09 GSXR/88 iroc/91 RS B4C
Engine: 600cc/l5.7/5.7
Transmission: 6 speed/TH 350/auto
Axle/Gears: 45tooth rear?/3.23/3.42
^^^ agree 245's are too narrow, i'd run a 275 up front and 295's out back
Have you considered these
http://www.oewheelsllc.com/Wheels-fo...01860-3-1.html
with a 10.5 wide rear tires you will need to massage your inner fender,
Old Aug 20, 2010 | 11:47 PM
Pateman91's Avatar
Axle/Gears: Stock
Thanks guys, & this is exactly why I posted my setup ideas before purchasing them! With me running the 275's in the front & 295's in the back I would be alright with no rub whatsoever?
HoosierinWA
Oct 7, 2015 10:15 AM
jaridjohn
Oct 5, 2015 07:01 AM
gord327
Sep 29, 2015 10:18 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
mrdevontay
Sep 2, 2015 08:04 PM
